Hi
I wish to use concurrent_unordered_map with some custom types
I declare the unordered map as follows
typedef tbb::concurrent_unordered_map<openvdb::Coord, std::vector<openvdb::Vec3R>, anotherHashCompare> unordrd_vox_coordlist;
where another hash compare is defined as
struct anotherHashCompare { static size_t hash( const openvdb::Coord &x ) { size_t h = 0; int s; s=x.x(); h = (h*17)^s; s=x.y(); h = (h*17)^s; s=x.z(); h = (h*17)^s; return ((size_t)h); } //! True if strings are equal static bool equal( const openvdb::Coord &x, const openvdb::Coord &y ) { return x==y; } };
Now when i want to insert something into this map object
unordrd_vox_coordlist intrmd_nrmls;
like this
intrmd_nrmls.insert(std::make_pair(it_rel_neigh->first,per_vox_intermed_nrmls));
where
is of type
and
it_rel_neigh->first
is of type
openvdb::Coord
I get an error as follows
tbb_structs1.h: In member function ‘void normals_unordered::operator()(const tbb::interface5::internal::concurrent_unordered_base<tbb::interface5::concurrent_unordered_map_traits<openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> >, tbb::interface5::internal::hash_compare<openvdb::v4_0_1::math::Coord, anotherHashCompare, std::equal_to<openvdb::v4_0_1::math::Coord> >, tbb::tbb_allocator<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > >, false> >::range_type&) const’: tbb_structs1.h:205:4: error: expected unqualified-id before ‘}’ token } ^ In file included from /home/rohit/Downloads/tbb2017_20170226oss/include/tbb/concurrent_hash_map.h:47:0, from /home/rohit/openvdb/include/openvdb/tree/Tree.h:51, from /home/rohit/openvdb/include/openvdb/Grid.h:39, from /home/rohit/openvdb/include/openvdb/openvdb.h:39, from tbb_structs1.h:16, from pointsv9.cpp:6: /home/rohit/Downloads/tbb2017_20170226oss/include/tbb/internal/_tbb_hash_compare_impl.h: In instantiation of ‘std::size_t tbb::interface5::internal::hash_compare<Key, Hasher, Key_equality>::operator()(const Key&) const [with Key = openvdb::v4_0_1::math::Coord; Hasher = anotherHashCompare; Key_equality = std::equal_to<openvdb::v4_0_1::math::Coord>; std::size_t = long unsigned int]’: /home/rohit/Downloads/tbb2017_20170226oss/include/tbb/internal/_concurrent_unordered_impl.h:1276:53: required from ‘std::pair<typename tbb::interface5::internal::split_ordered_list<typename Traits::value_type, typename Traits::allocator_type>::iterator, bool> tbb::interface5::internal::concurrent_unordered_base<Traits>::internal_insert(ValueType&&, tbb::interface5::internal::concurrent_unordered_base<Traits>::nodeptr_t) [with AllowCreate = tbb::internal::bool_constant<true>; ValueType = std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > >; Traits = tbb::interface5::concurrent_unordered_map_traits<openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> >, tbb::interface5::internal::hash_compare<openvdb::v4_0_1::math::Coord, anotherHashCompare, std::equal_to<openvdb::v4_0_1::math::Coord> >, tbb::tbb_allocator<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > >, false>; typename tbb::interface5::internal::split_ordered_list<typename Traits::value_type, typename Traits::allocator_type>::iterator = tbb::interface5::internal::solist_iterator<tbb::interface5::internal::split_ordered_list<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > >, tbb::tbb_allocator<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > > >, std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > >; tbb::interface5::internal::concurrent_unordered_base<Traits>::nodeptr_t = tbb::interface5::internal::split_ordered_list<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > >, tbb::tbb_allocator<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > > >::node*]’ /home/rohit/Downloads/tbb2017_20170226oss/include/tbb/internal/_concurrent_unordered_impl.h:980:73: required from ‘std::pair<typename tbb::interface5::internal::split_ordered_list<typename Traits::value_type, typename Traits::allocator_type>::iterator, bool> tbb::interface5::internal::concurrent_unordered_base<Traits>::insert(tbb::interface5::internal::concurrent_unordered_base<Traits>::value_type&&) [with Traits = tbb::interface5::concurrent_unordered_map_traits<openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> >, tbb::interface5::internal::hash_compare<openvdb::v4_0_1::math::Coord, anotherHashCompare, std::equal_to<openvdb::v4_0_1::math::Coord> >, tbb::tbb_allocator<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > >, false>; typename tbb::interface5::internal::split_ordered_list<typename Traits::value_type, typename Traits::allocator_type>::iterator = tbb::interface5::internal::solist_iterator<tbb::interface5::internal::split_ordered_list<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > >, tbb::tbb_allocator<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > > >, std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > >; tbb::interface5::internal::concurrent_unordered_base<Traits>::value_type = std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > >]’ tbb_structs1.h:202:83: required from here /home/rohit/Downloads/tbb2017_20170226oss/include/tbb/internal/_tbb_hash_compare_impl.h:46:44: error: no match for call to ‘(const anotherHashCompare) (const openvdb::v4_0_1::math::Coord&)’ return ((size_t)my_hash_object(key)); ^ common.mk:52: recipe for target 'pointsv9.o' failed make: *** [pointsv9.o] Error 1
Can someone kindly help me figure out why i get this error? Instead when i insert into a concurent_hash_map using a const_accessor the hash map and a declaration of the hasp map as follows
typedef tbb::concurrent_hash_map<openvdb::Coord, std::vector<openvdb::Vec3R>, MyHashCompare> vec_of_coords;
works fine.
Hi Rohit,
The following message says about some problem near line #205 in tbb_structs1.h:
Could you share the file or provide a code snippet near this line, please?
Alex
HI Alex
I apologize it seems i did a mistake in pasting the error the error is like this
rohit@rohit-desktop-work:~/Documents/openvdb_codes$ make g++ -O3 -fPIC -fopenmp -std=c++11 -pthread -I./ -I/usr/local/include/eigen3 -I/home/rohit/openvdb/include -I/usr/local/include -I/home/rohit/Downloads/tbb2017_20170226oss/include -I/usr/local/include -o pointsv9.o -c pointsv9.cpp In file included from /home/rohit/Downloads/tbb2017_20170226oss/include/tbb/concurrent_hash_map.h:47:0, from /home/rohit/openvdb/include/openvdb/tree/Tree.h:51, from /home/rohit/openvdb/include/openvdb/Grid.h:39, from /home/rohit/openvdb/include/openvdb/openvdb.h:39, from tbb_structs1.h:16, from pointsv9.cpp:6: /home/rohit/Downloads/tbb2017_20170226oss/include/tbb/internal/_tbb_hash_compare_impl.h: In instantiation of ‘std::size_t tbb::interface5::internal::hash_compare<Key, Hasher, Key_equality>::operator()(const Key&) const [with Key = openvdb::v4_0_1::math::Coord; Hasher = anotherHashCompare; Key_equality = std::equal_to<openvdb::v4_0_1::math::Coord>; std::size_t = long unsigned int]’: /home/rohit/Downloads/tbb2017_20170226oss/include/tbb/internal/_concurrent_unordered_impl.h:1276:53: required from ‘std::pair<typename tbb::interface5::internal::split_ordered_list<typename Traits::value_type, typename Traits::allocator_type>::iterator, bool> tbb::interface5::internal::concurrent_unordered_base<Traits>::internal_insert(ValueType&&, tbb::interface5::internal::concurrent_unordered_base<Traits>::nodeptr_t) [with AllowCreate = tbb::internal::bool_constant<true>; ValueType = std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > >; Traits = tbb::interface5::concurrent_unordered_map_traits<openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> >, tbb::interface5::internal::hash_compare<openvdb::v4_0_1::math::Coord, anotherHashCompare, std::equal_to<openvdb::v4_0_1::math::Coord> >, tbb::tbb_allocator<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > >, false>; typename tbb::interface5::internal::split_ordered_list<typename Traits::value_type, typename Traits::allocator_type>::iterator = tbb::interface5::internal::solist_iterator<tbb::interface5::internal::split_ordered_list<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > >, tbb::tbb_allocator<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > > >, std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > >; tbb::interface5::internal::concurrent_unordered_base<Traits>::nodeptr_t = tbb::interface5::internal::split_ordered_list<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > >, tbb::tbb_allocator<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > > >::node*]’ /home/rohit/Downloads/tbb2017_20170226oss/include/tbb/internal/_concurrent_unordered_impl.h:980:73: required from ‘std::pair<typename tbb::interface5::internal::split_ordered_list<typename Traits::value_type, typename Traits::allocator_type>::iterator, bool> tbb::interface5::internal::concurrent_unordered_base<Traits>::insert(tbb::interface5::internal::concurrent_unordered_base<Traits>::value_type&&) [with Traits = tbb::interface5::concurrent_unordered_map_traits<openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> >, tbb::interface5::internal::hash_compare<openvdb::v4_0_1::math::Coord, anotherHashCompare, std::equal_to<openvdb::v4_0_1::math::Coord> >, tbb::tbb_allocator<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > >, false>; typename tbb::interface5::internal::split_ordered_list<typename Traits::value_type, typename Traits::allocator_type>::iterator = tbb::interface5::internal::solist_iterator<tbb::interface5::internal::split_ordered_list<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > >, tbb::tbb_allocator<std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > > >, std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > > >; tbb::interface5::internal::concurrent_unordered_base<Traits>::value_type = std::pair<const openvdb::v4_0_1::math::Coord, std::vector<openvdb::v4_0_1::math::Vec3<double> > >]’ tbb_structs1.h:202:83: required from here /home/rohit/Downloads/tbb2017_20170226oss/include/tbb/internal/_tbb_hash_compare_impl.h:46:44: error: no match for call to ‘(const anotherHashCompare) (const openvdb::v4_0_1::math::Coord&)’ return ((size_t)my_hash_object(key)); ^ common.mk:52: recipe for target 'pointsv9.o' failed make: *** [pointsv9.o] Error 1
I apologize once again. Kindly suggest what could be the issue with the error above.
Rohit
According to the error message the object of the anotherHashCompare class does not have an appropriate operator() for the object of the openvdb::v4_0_1::math::Coord type. It can be caused if anotherHashCompare::operator() is not const.
Alex
