2452 Discussions
test_semaphore not build/run in Makefile.test. Intentionally ?
Blas_Rodriguez_Somoz
In Makefile.test (tbb40_20111130) there is not a rule to build test_semaphore but there is something suspicious at line 151:
semaphore.$(OBJ)
which doesn't make sense. Perhaps the content of this line should be:
test_semaphore.$(TEST_EXT)
About the test run, the corresponding line is commented, but is not strange since the executable is not build.
At least in OS X the test build and run without problems.
Should this test be build and run or not ?
RafSchietekat
Black Belt
{x86,Power}/Linux doesn't seem to have a problem, either (in a version based on update 1).
Vladimir_P_1234567890
Bug, thanks for notification.
--Vladimir
