throttling number of threads
Brian_Budge
Hi -
Is it possible to throttle the maximum number of threads used by the task scheduler or for a parallel launch? I searched the forums for this, but couldn't find anything. Probably just the wrong key words.
RafSchietekat
Valued Contributor III
Provide a non-default argument to task_scheduler_init.
turks
Quoting - Raf Schietekat
Raf, could you explain further ? What would be a "non default argument" ?
-T
Vivek_Rajagopalan
Quoting - turks
-T
From the docs : http://www.threadingbuildingblocks.org/files/documentation/a00114.html
task_scheduler_init (int number_of_threads=automatic, stack_size_type thread_stack_size=0)
Shorthand for default constructor followed by call to intialize(number_of_threads).
task_scheduler_init tinit(4); // restrict tbb worker threads to 4, even if you have more or less hardware threads available
Terry_W_Intel
Quoting - turks
-T
The task_scheduler_init() can take two optional arguments:
task_scheduler_init( int number_of_threads=automatic, stack_size_type thread_stack_size=0);
So, you can ask directly for p threads by doing this:
task_scheduler_init init(p);
Cheers,
Terry
turks
Is there any way to know that if you ask for only 2 worker threads on an 8 core machine that you actually got 2 and
not 8 ? If I throttle back the worker threads at init time to 2 it uses as much CPU as when I init with 8.
RafSchietekat
Quoting - turks
The first task_scheduler_init instance sets the number of worker threads; any additional instances have no say in the matter. If you did provide the number to the first instance, what are the symptoms?
turks
Symptoms of initing to 1 or 2 threads is that my pipeline is using a lot of CPU. I assume the default (if no argument is given) is 8 on a machine with 2 quad-core chips ?
RafSchietekat
"Symptoms of initing to 1 or 2 threads is that my pipeline is using a lot of CPU."
That's not very specific.
"I assume the default (if no argument is given) is 8 on a machine with 2 quad-core chips ?"
Yes, unless you also have hyperthreading.
