timed tasks?
alexander
Hi TBB Experts!
I am currently using some (allocators, containers, atomic functions etc..) of the TBB components in my open-source streaming server project (mammoth-project.org), and I'm very happy with that!
The server basically consists of two threadpools; one for io processing using boost::asio and one for heavier (non-blocking) protocol processing (video on demand for ex.). For the latter I have implemented 'timed-tasks', whichare simple tasks that are executed approximately afterx (0-????) amount ofms. Each task is able to requeue itsself and is executed when its timer elapses. For that I simply implemented amultiset (sorted on tasktimer)combined with a conditionand a mutexusing a 'timed_wait'.
Now I would like to replace my 'task scheduler' with the tbb scheduler. My question: is it possible (without having to dive into tbb task.cpp/task.hpp code) to implementmy 'timed tasks' (in a non-intrusive way) and use the queuing meschanism the tbb scheduler has? Orwould you advise me to keep my current task pool?
Basically; I would loveto do the following:
root->spawn(t, 100); //spawn task t after approximately 100ms.
I look forward to your response!
Alexander
Dmitry_Vyukov
Valued Contributor I
You can try something like the following. Create separate thread for management of timed tasks. Timed spawn will actually just send a message to that thread. The thread calculates the nearest time for firing and blocks until that time, when it wakes up it spawns normal TBB task.
Here is crude pseudo-code:
[cpp]message_queue q;
void timed_spawn(task* t, int delay)
t->set_affinity(my_thread_id);
q.enqueue(msg(t, delay));
void timed_thread_routine()
  spawn_root_and_wait(new timed_management_task());
void timed_management_task::execute()
  for (;;)
    what = wait_for_something();
    if (what == fire_task)
       t = get_next_task();
       spawn(t);
    else if (what == new_incoming_message)
       m = q.dequeue();
       remember_task_and_recalculate_next_fire_time(m->task, m->delay);
    else if (what == terminate);
      return;
[/cpp]
RafSchietekat
Valued Contributor III
"Or would you advise me to keep my current task pool?" Yes.
