trying to run tbb examples
Penunuri__David
I installed I_tbb_2018.4.222.tgz but cannot find tbbvars.* scripts as required to build the examples.  Where are these located?
Nikita_P_Intel
Hi David,
tbbvars.sh script should be located at $TBB_INSTALL_DIR/bin folder.
Thanks, Nikita
Penunuri__David
I downloaded and installed TBB.  When I source the tbbvars.sh file I get the message: “Badly placed ()’s.”
Is this a problem?
