warning: leaked X task objects
mklvml
This warning seems undocumented. Could you explain its meaning?
RafSchietekat
Black Belt
If you ask a question here, please make an effort and provide details even if you don't see whether they might be relevant.
SergeyKostrov
Valued Contributor II
>>...This warning seems undocumented. Could you explain its meaning?
There is a __TBB_COUNT_TASK_NODES macro. When the __TBB_COUNT_TASK_NODES macro is
defined a verification will be done to detect "Task Leaks".
In another words, it warns that some resources allocatedfor tasksare notreleaseddue to some reason.
A membermy_task_node_countshould be equal to zero if everithing was fine. If it is not zero a
'runtime_warning( ... )' method will becalled andthe warning messageis displayed.
Here is some summary from the TBB's sources:
market.h
#if __TBB_COUNT_TASK_NODES
//! Net number of nodes that have been allocated from heap.
/** Updated each time a scheduler or arena is destroyed. */
atomic my_task_node_count;
#endif /* __TBB_COUNT_TASK_NODES */
void update_task_node_count( intptr_t delta )
my_task_node_count += delta;
market.cpp
void market::destroy()
if ( my_task_node_count )
runtime_warning( "Leaked %ld task objects\n", ( long )my_task_node_count );
this->~market();
NFS_Free( this );
__TBB_InitOnce::remove_ref();
scheduler.cpp
void generic_scheduler::free_scheduler()
my_market->update_task_node_count( my_task_node_count );
arena.cpp
void arena::free_arena()
my_market->update_task_node_count( -drained );
There is also a Test-Case at:
\Src\Test\test_task_leaks.cpp
