2481 Discussions
what's the different between boost.threadpool and tbb?
Liu_M_1
I am a begineer with tbb.As far I know,tbb looks like a threadpool which  could handle tasks.And boost.threadpool can do the same thing.
So,what's the different between boost.threadpool and tbb?
robert-reed
Valued Contributor II
The Boost threadpool library offers a rudimentary thread pool with fairly low-level support for threads and tasks:
boost::threadpool::future< Result >Experimental. Do not use in production code. TODO
boost::threadpool::empty_controller< Pool >SizePolicyController which provides no functionality
boost::threadpool::fifo_scheduler< Task >SchedulingPolicy which implements FIFO ordering
boost::threadpool::immediately< Pool >ShutdownPolicy which does not wait for any tasks or worker termination
boost::threadpool::lifo_scheduler< Task >SchedulingPolicy which implements LIFO ordering
boost::threadpool::looped_task_funcLooped task function object
boost::threadpool::prio_scheduler< Task >SchedulingPolicy which implements prioritized ordering
boost::threadpool::prio_task_funcPrioritized task function object
boost::threadpool::resize_controller< Pool >SizePolicyController which allows resizing
boost::threadpool::static_size< Pool >SizePolicy which preserves the thread count
boost::threadpool::thread_pool< Task, SchedulingPolicy, SizePolicy, SizePolicyController, ShutdownPolicy >Thread pool
boost::threadpool::wait_for_active_tasks< Pool >ShutdownPolicy which waits for the completion of all active tasks and the worker termination afterwards
boost::threadpool::wait_for_all_tasks< Pool >ShutdownPolicy which waits for the completion of all tasks and the worker termination afterwards
Intel Threading Building Blocks offers a thread pool but supports it with a lot more scheduling and policy and generic algorithms and thread-safe container support, including parallel_for, parallel_reduce,  pipelines,  flow::graph and more, plus a multi-thread aware memory allocator that improves allocation overhead and more.  I would encourage you as a beginning TBB user to read the available documentation (here would be a good place to start: http://software.intel.com/sites/products/documentation/doclib/tbb_sa/help/index.htm#tbb_userguide/title.htm ) and learn for yourself how much more Intel TBB has to offer.
