2485 Discussions
windows 10 static/shared builds - which libs to use
spence__ian
I'm on Windows 10, command line using nvcc to link objects to a 64 bit .exe
I see there's various dlls & libs for windows 10, 64 bit:
\compilers_and_libraries_2020.0.166\windows\ipp\lib\intel64_win has .libs,
as does subdirectories \ipp\intel64_win\threaded has .libs
& \ipp\intel64_win\tl\ has
\ipp\intel64_win\tl\openmp\ with _tl.dll & _tl.lib
\ipp\intel64_win\tl\tbb\ with _tl.dll & _tl.lib
If I'm using TBB in my app, and linking to the TBB libs (tbb & tbbmalloc), which TBB (vc_mt or vc14) & static IPP .libs  do I link to? I thought the TBB libs were dynamic/shared, but I don't see any TBB .dlls, only TBB .libs
Here are the include contents of TBB app:
#include <base_ipp.h>
#include "ippcore.h"
#include "ipps.h"
#include "ippi.h"
#ifdef USE_TBB
#define TBB_PREVIEW_MEMORY_POOL 1
#include "task_scheduler_init.h"
#include "parallel_for.h"
#include "blocked_range2d.h"
#include "memory_pool.h"
using namespace tbb;
#endif
Ian
Mark_L_Intel
   Where have you downloaded TBB from? In general, you could download TBB from https://github.com/intel/tbb. And then build TBB using instructions there for your platform -- after that you should see dll files under, e.g. bin/intel64/vs14
Mark
