[windup] TBB for MinGW
leepl
Hallo, I know that the topic was already broached earlier but it isn't bright. The question is simple I know that TBB officially isn't supporting MinGW but whether somebody has version for this compiler. Can you upload it?.
Vladimir_P_1234567890
MinGW support was added to the 20090511 development release.
gianpatt
Sorry but, i can't find it.
I have downloaded the 20090511 version but when run compiler "make compiler=gcc " i have this message "Compiler gcc is not supported on windows. Add build/windows.gcc.inv file....".
What's wrong? Thank you for your support.
Quoting - gianpatt
Please find required file next to source archive on the download page. Thanks for pointing this:) the file should be copied to the build/ folder.
Vladimir
gianpatt
Vladimir
Sorry again Vladimir, i can't find it....
Anton_Pegushin
New Contributor II
Quoting - gianpatt
Hi, what Vladimir meant was that if you go to the download page of that particular package (http://www.threadingbuildingblocks.org/ver.php?fid=139), you'll find that Vladimir added a windows.gcc.inc file (separate download), that needs to go to the /build directory. After that support for MinGW support will work.
prakointel
Do we really need to use mingw? Coz i jus installed the TBB Visual Studio plugin. Does the installation procedure vary with the processor architechture like Intel or AMD?
