Intel vPro® Platform
7SOKTG
I am getting logs as belowin SCS.I can however ping the machines from the provision server.any idea?Provisioning process is withheld.
Cannot connect Intel AMT device to 10.104.44.42.Cannot connect Intel AMT device to 10.112.14.63.Cannot connect Intel AMT device to 10.112.9.197.Cannot connect Intel AMT device to 10.112.9.78.Cannot connect Intel AMT device to 10.116.128.57.Cannot connect Intel AMT device to 10.116.128.57.Cannot connect Intel AMT device to 10.116.140.50.Cannot connect Intel AMT device to 10.72.46.101.Cannot connect Intel AMT device to 10.72.48.82.Cannot connect Intel AMT device to 10.74.32.186.Cannot connect Intel AMT device to 10.74.32.94.Cannot connect Intel AMT device to 10.74.46.117.Cannot connect Intel AMT device to 10.74.49.102.Cannot connect Intel AMT device to 10.80.13.29.Cannot connect Intel AMT device to 10.80.13.33.Cannot connect Intel AMT device to 10.88.16.74.Cannot handle provisioning exception: (0xCFFF06AC) SOAP Failure (21): getFullCoreVersion: Timeout - connect failed in tcp_connect().Cannot handle provisioning exception: (0xCFFF06AC) SOAP Failure (21): getFullCoreVersion: Timeout - connect failed in tcp_connect().Cannot handle provisioning exception: (0xCFFF06AC) SOAP Failure (21): getFullCoreVersion: Timeout - connect failed in tcp_connect().Cannot handle provisioning exception: (0xCFFF06AC) SOAP Failure (21): getFullCoreVersion: Timeout - connect failed in tcp_connect().Cannot handle provisioning exception: (0xCFFF06AC) SOAP Failure (21): getFullCoreVersion: Timeout - connect failed in tcp_connect().Cannot handle provisioning exception: (0xCFFF06AC) SOAP Failure (21): getFullCoreVersion: Timeout - connect failed in tcp_connect().Cannot handle provisioning exception: (0xCFFF06AC) SOAP Failure (21): getFullCoreVersion: Timeout - connect failed in tcp_connect().Cannot handle provisioning exception: (0xCFFF06AC) SOAP Failure (21): getFullCoreVersion: Timeout - connect failed in tcp_connect().Cannot handle provisioning exception: (0xCFFF06AC) SOAP Failure (21): getFullCoreVersion: Timeout - connect failed in tcp_connect().Cannot handle provisioning exception: (0xCFFF06AC) SOAP Failure (21): getFullCoreVersion: Timeout - connect failed in tcp_connect().<span style="color: # 0...
what is the version of the SCS that you are using and what is the firmware?
