Intel vPro® Platform
3072 Discussions
AHCI drivers for Intel desktop board DQ35JO
Hi All,
I would like to run my Intel desktop board DQ35JO chipset Q35 in AHCI
mode I have downloaded Intel Matrix Storage manager and placed the
necessary files on a floppy disk. During Xp installation I select F6
and insert the floppy.
I get the following list of drivers
ESB2 SATA AHCI controller
ICH7R/DH SATA AHCI controller
ICH7M/MDH SATA AHCI controller
ICH8R/DH/DO SATA AHCI controller
ICH8M-E/M SATA AHCI controller
ICH9R/DO/DH SATA AHCI controller
ICH9M-E/M SATA AHCI controller
ICH10D/DO SATA AHCI controller
ICH10R SATA AHCI controller
Does anyone know which drivers I should install. I've tried a couple but get Blue screen
Any suggestions would be gratefully received
thanks
Hi there,
First thing i will do is to flash my bios to the latest version using the recovery mode.
Then i will set my bios settings Advanced >> Drive >> Configure SATA as AHCI & ATA/IDE Mode to Enhanced.
Then i will download the F6 driver from the website below: (note if you are using 32 bit OS,use the 32 bit driver otherwise use 64 bit)
Website: http://downloadcenter.intel.com/download.aspx?url=/15251/eng/STOR_all32_f6flpy32_8.7.0.1007_PV.zip&DwnldId=15251&ProductID=2783&lang=eng http://downloadcenter.intel.com/download.aspx?url=/15251/eng/STOR_all32_f6flpy32_8.7.0.1007_PV.zip&DwnldId=15251&ProductID=2783&lang=eng
Copy all the extracted file to an internal floppy disk if you are using Windows XP.
Press F6 for XP to load the driver
Scroll down and look for the driver below
Your driver will be: iaAHCI_ICH8RDHDO = iaAHCI_ICH9RDODH = "Intel(R) ICH9R/DO/DH SATA AHCI Controller"
If there is no internal floppy drive, then try to use a software called Nlite to slipstream the driver with the OS, this way you are creating a new OS already embedded with the driver. Burn it on a CD.
Other than this i dont have any other information. Try to see if it works fine wen Configure SATA as IDE as a test. And try with another OS CD or simply try with Vista to see if it works as Vista already have the driver.
Aryan
Hi there,
Aryan
from page 13 of the technical spec PDF for your motherboard here:
http://www.intel.com/support/motherboards/desktop/dq35jo/sb/CS-029387.htm
Lists south bridge as:
Intel 82801IDO I/O Controller Hub (ICH9DO)
