Intel vPro® Platform
3059 Discussions
AMT 7.0 + Q67 chips are here !
At last! I couldn't wait for those boards.
I am with the Intel Desktop Board group supporting the Q-series Exectutive boards. Due to the recently announced Chipset Design Error (see http://www.intel.com/consumer/products/processors/chipset.htm http://www.intel.com/consumer/products/processors/chipset.htm for details) we've had to pull back the boards that were shipped previously for launch activities. The new boards with the B3 chipsets are just now arriving at some of the larger retailers. Google shows several sites now selling the DQ67SW boards (including Amazon.com); the other three boards should be available within the next month or two as they filter through the distribution channels. I suggest you keep monitoring the retail sites for the BOX SKU of the board (i.e., BOXDQ67SW, etc).
Craig Watkins
ICBD Tech Marketing Engineer
Thank you very much sir.
You information is appreciated.
Dear,
I have an intel dq67ow and an i5 2300 processor, but i can't get it to work properly. When I try to connect via vnc viewer plus it says that I don't have the rights to connect and when I use manageability commander tool it says KVM isn't supported. Did I miss something?
kind regards
Kevin
Hello /message/117405# 117405 Radu Bogdan,
I think you've bougtht a wrong CPU. This CPU doesn't support KVM. Here you can check supported list published from intel.
Best Regards!
