Intel vPro® Platform
3052 Discussions
CIRA. Connection Status: Outside versus Disconnect
VeeDub
I'm using MeshCentral to manage AMT endpoints.
I have a number of endpoints that are connecting fine.
However, I have some endpoints that appear to make an initial connection to MeshCentral, but don't continue the connection.
From an AMT standpoint here is an endpoint that is working versus an endpoint that is not.
Working
C:\ZEN\MeshCentral>meshcmd amtinfo
Intel AMT v16.1.30, activated in Admin Control Mode (ACM).
Wired Enabled, DHCP, CC:96:E5:37:4A:7F
DNS suffix: alleanza.local
Connection Status: Outside, CIRA: Connected to mc1.zen.net.au, Periodic.
Not working
C:\ZEN\MeshCentral\ZEN>meshcmd amtconfig --url wss://mc1.zen.net.au/apf.ashx --id --serverhttpshash
(I have hidden some of the info in case it is sensitive)
Setting up MEI...
Starting Intel AMT configuration...
Started APF tunnel...
Checking Intel AMT state...
Intel AMT connected.
Performing Commit...
Enabled TLS, holding 10 seconds...
Added server root certificate.
Created new MPS server.
Created new MPS policy.
Environment detection set.
Enabled redirection features.
Enabled KVM.
Fetching hardware inventory.
Done.
C:\ZEN\MeshCentral\ZEN>meshcmd amtinfo
Intel AMT v12.0.94, activated in Admin Control Mode (ACM).
Wired Enabled, Static, E4:54:E8:92:A7:FB, 10.254.242.100
Connection Status: Direct, CIRA: Disconnected.
I'm looking for some information about Connection Status. Outside versus Direct.
Can you provide an explanation or refer me to some documentation where I can learn about the differences?
Thank you.
Suneesh
Hello VeeDub,
Good day.
Thank you for sharing the initial details. Before we proceed, could you please provide the following information:
  • Are the working and non-working endpoints within the domain or are they out-of-band.
  • Could you also share details of these endpoints. You may retrieve this information from the ECT logs of both the working and non-working endpoints. And share us the ECT logs.
Intel® EMA Configuration Tool (ECT) Logs:
-Download the tool from the following link: Intel® EMA Configuration Tool
-Installation:
  • Download and unzip the tool.
  • Double-click the .msi file and follow the installation prompts.
-Run the Tool:
a. Open a command prompt as an administrator (or use Windows PowerShell*).
b. Navigate to the installation folder (default: C:\Program Files (x86)\Intel\EMAConfigTool).
c. Run the following command:
EMAConfigTool.exe --verbose
Suneesh_Intel
VeeDub
Hello Suneesh,
Are the working and non-working endpoints within the domain or are they out-of-band?
I don't understand this question. You may need to provide additional information.
The endpoints are at different physical locations.
However all PC's are part of Windows Active Directory domains (but they're different AD domains).
This is from the Endpoint that is NOT connecting via CIRA.
C:\Program Files (x86)\Intel\EMAConfigTool>EMAConfigTool.exe --verbose
Intel EMA Configuration Tool
Application Version: 1.1.0.183
Scan Date: 8/11/2024 11:38:25 AM
*** Host Computer Information ***
Computer Name: BBOX4
Manufacturer: Dell Inc.
Model: OptiPlex 7070
Processor: Intel(R) Core(TM) i5-9500 CPU @ 3.00GHz
Windows Version: Microsoft Windows Server 2019 Datacenter
BIOS Version: 1.28.0
UUID: 4C4C4544-004D-4810-8030-B8C04F523133
*** SMBIOS Information ***
AMT Supported: True
AMT Enabled: True
SMBIOS ME SKU: Intel(R) Full AMT Manageability
SMBIOS ME Version: 12.0.94.2380
KVM Supported: True
SOL Supported: True
USB-R supported in BIOS: True
RSE Supported: False
*** ME Information ***
State: Provisioned
Control Mode: Admin
Driver Installed: True
Driver Version: 2336.5.2.0
PKI DNS Suffix: Not Found
LMS State: Running
LMS Version: 2336.5.2.0
MicroLMS State: NotPresent
EHBC Enabled: False
*** ME Capabilities ***
AMT in Enterprise Mode: True
TLS Enabled: True
HW Crypto Enabled: True
Current Provisioning state: POST_PROVISIONING_STATE
NetworkInterface Enabled: True
SOL Enabled: True
IDER Enabled: True
FWUpdate Enabled: False
LinkIsUp state: True
KVM Enabled: True
RSE Enabled: False
*** Power Management Capabilities ***
Supported Power States:
5: PowerCycle_Off_Soft
8: Off_Soft
2: On
10: Master_Bus_Reset
11: NMI
4: SleepDeep
12: Off_Soft_Graceful
14: MasterBusReset_Graceful
Power Change Capabilities:
2: On
3: SleepLight
4: SleepDeep
7: Hibernate
8: Off_Soft
*** CIRA Information ***
CIRA Server: Not Found
CIRA Connection Status: NOT_CONNECTED
CIRA Connection Trigger: USER_INITIATED
*** ME Wired Network Information ***
Wired Interface Enabled: True
Link Status: Up
IP Address: 10.254.242.100
MAC Address: E4:54:E8:92:A7:FB
DHCP Enabled: False
DHCP Mode: Unknown
DNS Suffix (from OS): Not Found
*** ME Wireless Network Information ***
ME Wireless Interface Not Detected
*** Root Certificate Hash Entries ***
Root Cert 1: Go Daddy Class 2 CA, SHA256, C3:84:6B:F2:4B:9E:93:CA:64:27:4C:0E:C6:7C:1E:CC:5E:02:4F:FC:AC:D2:D7:40:19:35:0E:81:FE:54:6A:E4, Active, Default;
Root Cert 2: Go Daddy Root CA - G2, SHA256, 45:14:0B:32:47:EB:9C:C8:C5:B4:F0:D7:B5:30:91:F7:32:92:08:9E:6E:5A:63:E2:74:9D:D3:AC:A9:19:8E:DA, Active, Default;
Root Cert 3: Comodo AAA CA, SHA256, D7:A7:A0:FB:5D:7E:27:31:D7:71:E9:48:4E:BC:DE:F7:1D:5F:0C:3E:0A:29:48:78:2B:C8:3E:E0:EA:69:9E:F4, Active, Default;
Root Cert 4: Starfield Class 2 CA, SHA256, 14:65:FA:20:53:97:B8:76:FA:A6:F0:A9:95:8E:55:90:E4:0F:CC:7F:AA:4F:B7:C2:C8:67:75:21:FB:5F:B6:58, Active, Default;
Root Cert 5: Starfield Root CA - G2, SHA256, 2C:E1:CB:0B:F9:D2:F9:E1:02:99:3F:BE:21:51:52:C3:B2:DD:0C:AB:DE:1C:68:E5:31:9B:83:91:54:DB:B7:F5, Active, Default;
Root Cert 6: VeriSign Class 3 Primary CA-G5, SHA256, 9A:CF:AB:7E:43:C8:D8:80:D0:6B:26:2A:94:DE:EE:E4:B4:65:99:89:C3:D0:CA:F1:9B:AF:64:05:E4:1A:B7:DF, Active, Default;
Root Cert 7: Baltimore CyberTrust Root, SHA256, 16:AF:57:A9:F6:76:B0:AB:12:60:95:AA:5E:BA:DE:F2:2A:B3:11:19:D6:44:AC:95:CD:4B:93:DB:F3:F2:6A:EB, Active, Default;
Root Cert 8: Cybertrust Global Root, SHA256, 96:0A:DF:00:63:E9:63:56:75:0C:29:65:DD:0A:08:67:DA:0B:9C:BD:6E:77:71:4A:EA:FB:23:49:AB:39:3D:A3, Active, Default;
Root Cert 9: Verizon Global Root, SHA256, 68:AD:50:90:9B:04:36:3C:60:5E:F1:35:81:A9:39:FF:2C:96:37:2E:3F:12:32:5B:0A:68:61:E1:D5:9F:66:03, Active, Default;
Root Cert 10: Entrust.net CA (2048), SHA256, 6D:C4:71:72:E0:1C:BC:B0:BF:62:58:0D:89:5F:E2:B8:AC:9A:D4:F8:73:80:1E:0C:10:B9:C8:37:D2:1E:B1:77, Active, Default;
Root Cert 11: Entrust Root CA, SHA256, 73:C1:76:43:4F:1B:C6:D5:AD:F4:5B:0E:76:E7:27:28:7C:8D:E5:76:16:C1:E6:E6:14:1A:2B:2C:BC:7D:8E:4C, Active, Default;
Root Cert 12: Entrust Root CA - G2, SHA256, 43:DF:57:74:B0:3E:7F:EF:5F:E4:0D:93:1A:7B:ED:F1:BB:2E:6B:42:73:8C:4E:6D:38:41:10:3D:3A:A7:F3:39, Active, Default;
Root Cert 13: VeriSign Universal Root CA, SHA256, 23:99:56:11:27:A5:71:25:DE:8C:EF:EA:61:0D:DF:2F:A0:78:B5:C8:06:7F:4E:82:82:90:BF:B8:60:E8:4B:3C, Active, Default;
Root Cert 14: Affirm Trust Premium, SHA256, 70:A7:3F:7F:37:6B:60:07:42:48:90:45:34:B1:14:82:D5:BF:0E:69:8E:CC:49:8D:F5:25:77:EB:F2:E9:3B:9A, Active, Default;
Root Cert 15: DigiCert Global Root CA, SHA256, 43:48:A0:E9:44:4C:78:CB:26:5E:05:8D:5E:89:44:B4:D8:4F:96:62:BD:26:DB:25:7F:89:34:A4:43:C7:01:61, Active, Default;
Root Cert 16: DigiCert Global Root G2, SHA256, CB:3C:CB:B7:60:31:E5:E0:13:8F:8D:D3:9A:23:F9:DE:47:FF:C3:5E:43:C1:14:4C:EA:27:D4:6A:5A:B1:CB:5F, Active, Default;
Root Cert 17: DigiCert Global Root G3, SHA256, 31:AD:66:48:F8:10:41:38:C7:38:F3:9E:A4:32:01:33:39:3E:3A:18:CC:02:29:6E:F9:7C:2A:C9:EF:67:31:D0, Active, Default;
Root Cert 18: DigiCert Trusted Root G4, SHA256, 55:2F:7B:DC:F1:A7:AF:9E:6C:E6:72:01:7F:4F:12:AB:F7:72:40:C7:8E:76:1A:C2:03:D1:D9:D2:0A:C8:99:88, Active, Default;
Root Cert 19: GlobalSign NP RSA CA 2018, SHA256, 67:54:0A:47:AA:5B:9F:34:57:0A:99:72:3C:FE:FA:96:A9:6E:E3:F0:D9:B8:BF:4D:EF:94:40:B8:06:5D:66:5D, Active, Default;
Root Cert 20: GlobalSign NP ECC CA 2018, SHA256, 72:24:39:52:22:CD:58:8C:4F:26:83:71:69:22:AD:DB:41:E3:9B:58:1A:C3:4F:A8:7B:39:EF:A8:96:FB:B3:9E, Active, Default;
Root Cert 21: GlobalSign Root CA - R3, SHA256, CB:B5:22:D7:B7:F1:27:AD:6A:01:13:86:5B:DF:1C:D4:10:2E:7D:07:59:AF:63:5A:7C:F4:72:0D:C9:63:C5:3B, Active, Default;
Root Cert 22: GlobalSign ECC Root CA - R5, SHA256, 17:9F:BC:14:8A:3D:D0:0F:D2:4E:A1:34:58:CC:43:BF:A7:F5:9C:81:82:D7:83:A5:13:F6:EB:EC:10:0C:89:24, Active, Default;
Root Cert 23: GlobalSign Root CA - R6, SHA256, 2C:AB:EA:FE:37:D0:6C:A2:2A:BA:73:91:C0:03:3D:25:98:29:52:C4:53:64:73:49:76:3A:3A:B5:AD:6C:CF:69, Active, Default;
Pausing before ending process in 3 sec. The duration of this pause can be adjusted using the --delayterm option.
The "working" endpoints are currently in use and I will provide the diagnostics later when I can access the system.
Thank you.
Vaughan
VeeDub
Here is the information from a "working" endpoint.
C:\ZEN\MeshCentral\Newcastle>meshcmd amtinfo
Intel AMT v12.0.95, activated in Admin Control Mode (ACM).
Wired Enabled, DHCP, 00:4E:01:A9:2E:75
The key is that the Connection Status for a working endpoint is always: 'Outside'
And a broken endpoint is always: 'Direct'.
Scan Date: 8/11/2024 1:43:55 PM
Computer Name: HOTDESK2
Model: Precision 3630 Tower
Processor: Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz
Windows Version: Microsoft Windows 10 Pro
BIOS Version: 2.30.0
UUID: 4C4C4544-0056-5710-8046-C6C04F525A32
AMT Supported: True
AMT Enabled: True
SMBIOS ME Version: 12.0.95.2489
KVM Supported: True
SOL Supported: True
State: Provisioned
Control Mode: Admin
Driver Version: 2406.5.5.0
LMS State: Running
LMS Version: 2406.5.5.0
EHBC Enabled: False
TLS Enabled: True
SOL Enabled: True
IDER Enabled: True
KVM Enabled: True
RSE Enabled: False
8: Off_Soft
2: On
11: NMI
4: SleepDeep
7: Hibernate
2: On
3: SleepLight
4: SleepDeep
7: Hibernate
8: Off_Soft
CIRA Server: mc1.zen.net.au
CIRA Connection Status: CONNECTED
CIRA Connection Trigger: TRIGGER_PERIODIC
Link Status: Up
IP Address: 0.0.0.0
MAC Address: 00:4E:01:A9:2E:75
DHCP Enabled: True
DHCP Mode: Passive
VeeDub
I have posted two replies and neither of them are showing?
VeeDub
I am going to try again.
Here is the meshcmd information from a "working" endpoint.
Here is the EMAConfigTool information.
Scan Date: 8/11/2024 2:01:16 PM
AMT Supported: True
AMT Enabled: True
KVM Supported: True
SOL Supported: True
State: Provisioned
Control Mode: Admin
LMS State: Running
EHBC Enabled: False
TLS Enabled: True
SOL Enabled: True
IDER Enabled: True
KVM Enabled: True
RSE Enabled: False
   8: Off_Soft
   2: On
   11: NMI
   4: SleepDeep
   7: Hibernate
   2: On
   3: SleepLight
   4: SleepDeep
   7: Hibernate
   8: Off_Soft
Link Status: Up
IP Address: 0.0.0.0
DHCP Enabled: True
DHCP Mode: Passive
VeeDub
Here is the EMAConfigTool info from a broken endpoint
AMT Supported: True
AMT Enabled: True
KVM Supported: True
SOL Supported: True
State: Provisioned
Control Mode: Admin
LMS State: Running
EHBC Enabled: False
TLS Enabled: True
SOL Enabled: True
IDER Enabled: True
KVM Enabled: True
RSE Enabled: False
   8: Off_Soft
   2: On
   11: NMI
   4: SleepDeep
   2: On
   3: SleepLight
   4: SleepDeep
   7: Hibernate
   8: Off_Soft
Link Status: Up
DHCP Enabled: False
DHCP Mode: Unknown
VeeDub
You also asked this question:
I'm not sure exactly what you're asking here.
Both computers are in Windows Active Directory domains.
The computers are at different sites, so the PC's are in different AD domains.
VeeDub
There is a problem with my replies that contain info from diagnostic tools.
I'm trying again.
This is info from an AMT endpoint that is connected.
VeeDub
Broken Endpoint / Not connected.
Suneesh
Hello VeeDub,
Good day.
Thank you for sharing the details.
Please run the following commands from the non-working endpoint and share us the output.
 - Open a PowerShell window as an administrator and verify the status for ports 16992, and 16993, and 443.
 - Run the command: `Test-NetConnection -ComputerName <FQDN> -port 16xx`
 - Run the command: `Test-NetConnection -ComputerName <FQDN> -port 443
Suneesh
VeeDub
Output
PS C:\Windows\System32\WindowsPowerShell\v1.0> test-netconnection -computername bbox4.cyberx1.local -port 16992
ComputerName : bbox4.cyberx1.local
RemoteAddress : fe80::1bb9:ca5:8813:2bad%6
RemotePort : 16992
InterfaceAlias : Ethernet 4
SourceAddress : fe80::1bb9:ca5:8813:2bad%6
TcpTestSucceeded : True
PS C:\Windows\System32\WindowsPowerShell\v1.0> test-netconnection -computername bbox4.cyberx1.local -port 16993
RemotePort : 16993
PS C:\Windows\System32\WindowsPowerShell\v1.0> test-netconnection -computername bbox4.cyberx1.local -port 443
WARNING: TCP connect to (fe80::1bb9:ca5:8813:2bad%6 : 443) failed
WARNING: TCP connect to (10.254.242.100 : 443) failed
RemotePort : 443
PingSucceeded : True
PingReplyDetails (RTT) : 0 ms
TcpTestSucceeded : False
Suneesh
Hello VeeDub,
Good day.
To clarify, CIRA is a software part on the EMA server side, and is activated while
installing the EMA software
According to the ECT logs, we see that the OS of the non-working endpoint shows windows server 2019 which is the server OS, and for the endpoint, the OS should be either windows 10 or windows 11.
And we also see that the CIRA server has been disconnected where the endpoint is trying to see the EMA server but unable to reach or connect.
Hence please install windows 10 or 11 on the non-working endpoint according to the prerequisite and also follow the trouble shooting steps given below:
1)Check the network configuration (firewalls, routing, DNS).
2)Verify the endpoint configuration in both EMA and CIRA server.
3)Test connectivity using tools like ping, telnet to confirm that the servers can reach each other on the required ports.
Kindly share your observation once done.
Thanks & Regards
Suneesh_Intel
VeeDub
Hello Sunnesh,
W11 Pro has the same behaviour.
With Admin Control Mode, can you explain the difference between Connection Status:
Outside
versus Direct?
Suneesh
Hello VeeDub,
Good day.
The Connection Status terms "Outside" and "Direct" are related to Mesh Central (a third-party tool) and not Intel AMT or EMA. Could you kindly share a screenshot of where you are seeing this message, so we can analyze it and assist you further.
Please note that Mesh Central is a third-party tool. You can find more information about it here: https://www.meshcommander.com/meshcentral2
Suneesh_Intel
VeeDub
Hello Suneesh,
There are details in the attachment W11_Pro.txt
Suneesh
Hello VeeDub,
Good day.
Thank you for sharing the logs.
From the logs provided:
Wired Enabled, Static, E4:54:E8:B5:80:95, 10.254.242.110
The "Connection Status: Direct" is reported by MeshCentral. Please note that MeshCentral is a third-party tool, and we recommend contacting their support team for further assistance with this issue. You can find additional information here: https://www.meshcommanderom/meshcentral2
If further assistance is necessary, do not hesitate to reply.
Suneesh_Intel
