Our pki certificate had expired, so we made a new one.
We added the new one to the server.
But when I go to the configuration profile, I don't see the option to add a certificate.
Thank you for your feedback
Hello AGUNS,
Greetings!
I understand the new Certificate has been installed into the Settings tab of the EMA web console, and you can see the three lines of the Certificate chain.
To ensure everything is set up correctly, could you confirm the following:
- Are both Certificates present in the Personal store of the IIS?
- Have you restarted the EMA services or the server after adding the new Certificate?
If the issue persists, kindly share the EMA server logs for further troubleshooting. You can find the logs at the following path:
[System drive]\Program File(x86)\Intel\Platform Manager\EmaLogs
Vijay N.
Hello AGUNS,
Greetings!
I wanted to follow up on the case and check if you could implement the suggestions I provided. Please let me know if you need further assistance.
Vijay N.
Hello AGUNS,
Greetings!
If further assistance is necessary, do not hesitate to reply.
Vijay N.
