Intel vPro® Platform
2761 Discussions
Compatibility-1333MHz/1600MHz RAM for Core i7 920 D0 SLBEJ
05:10 Hrs 9/18/2009||Friday
Hi, this is my System to be getting soon :
Processor - Core i7 920 D0 Stepping SLBEJ
Mobo - MSI X58 Pro-E Mobo
RAM - Corsair XMS3 TR3X3G1333C9 - 9-9-9-24 at VDIMM 1.5v
My Question is - Core i7 920 D0 supports RAM Memory Frequency 1066MHZ . But The Corsair RAM is 1333MHz, at 1.5v.
I DONOT WANT ANY OVERCLOCKING THINGS & JUST RUN MY SETUP FOR 3D-JOBS IN THE DFAULT STOCK FREQUENCY OF CPU & FREQUENCY OF RAM.
So if I want to keep all as-they-are ' Default Factory Stock Settings ' , -
1. Is This Corsair RAM willl Work Fine?
2. Will The RAM Frequency will work upto 1066 (Less Than its Default 1333 MHz) only ( when 'NO OC')
3. Will the Latency Timing 9-9-9-24 will change and the Voltage 1.5v will also change ?
4. If The Latency of 9-9-9-24 Changes then What Will be the NEW Latency setting and The NEW Voltage for of RAM ?
IS THIS WILL BE A VERY SAFE OPTION - TO KEEP THE FACTORY DEFAULT SETTING OF MOTHERBOARD & CPU & RAM ; I DO-NOT WANT TO CHANGE ANYTHING IN 'BIOS' ACTUALLY .
If These Memoery used -
Corsair DDR3-1333 (XMS3-10666C9*3CH) 9-9-9-24 at 1.5v or,
Corsair DDR3-1600 (Dominator-12800C8*XMP*3CH) 8-8-8-24 at 1.65v or,
Corsair DDR3-1866 (Dominator-15000C9*XMP*3CH) 9-9-9-24 at 1.65v .
So If I keep The All Motherboard BIOS , RAM Ltency in The Default Setting, What will happen ?
Is My Core i7 D0 will Gain Unwanted-Heat ?
RAM will gain Heat ?
Just Curious very much about - What will I See.
Your useful suggestions Please.
MICHELE_G_Intel
Hi user09,
This community specializes in questions related to Intel vPro technology. Please post your question in the Support Community (/community/tech http://communities.intel.com/community/tech).
Thanks!
Michele
Community Operations Manager
Is there any follow up to this issue? This is relevant to my interests. If it does not belong in this forum, could someone please link me to the new thread location?
