Intel vPro® Platform
3072 Discussions
Connect to endpoint fails (cont)
Benjovy
Hi Victor,
Let give this another shot as other thing got in the way.
community.intel.com/t5/Intel-vPro-Platform/Connect-to-endpoint-fails/m-p/1476403#M9950
To answer you questions.
To continue we will need the information below:
What exactly is the EMA version you are working with?
1.9.1
Please provide the exact AMT version being used on the endpoint(s).
v16.1.25, activated in Admin Control Mode (ACM)
Is the EMA server installed on a physical server or on a virtual machine?
VM
How many endpoints are you planning to have in your environment?
Less than 1000
Is the test endpoint you mentioned provisioned in CCM (client control mode) or ACM (Admin control mode)
Admin control mode.
  1. We will require a screenshot of both errors you get one while trying to log in to EMA and one while trying to connect to your test endpoint
Additionally, we are going to need a picture/screenshot of the enhanced key usage and the certification path of your PKI, secure, and root certificates.
I'll send you an email and not post it publicly as redacted info might be necessary for you to diagnose the issue.
  1. The logs below will be required as well:
  2. Ill send you an email and not post it publicly.
  • EMA logs from Server:
  • Ill send you an email and not post it publicly.
[System drive]\Program File(x86)\Intel\Platform Manager\EmaLogs
  • EMA log from the endpoint:
[System drive]\Program Files\Intel\EMA Agent\EMAagentlog
ditto
Victor_G_Intel
Hello Benjovy,
Thank you for your response.
We have sent you an email to request the missing information from your previous thread, feel free to reply to it.
Victor G.
Intel Technical Support Technician
