Intel vPro® Platform
3028 Discussions
Dell Latitude D630C - Reset ME Firmware
Simple question: How do you reset the Management Engine to factory defaults on a Dell Latitude D630C?
Trevor Sullivan
Systems Engineer
OfficeMax Corporation
MManz4
Here is what Dell Latitude D630c can do for un-provision:
The Un-Provision option allows you to reset the Intel AMT configuration to factory defaults. There are three types of un-provision:
  • Partial Un-provision – This option resets all of the Intel AMT settings to their default values but leaves the PID/PPS. The MEBx password remains untouched.
  • Full Un-provision – This option resets all of the Intel AMT settings to their default values. If a PID/PPS value is present, both values are lost. The MEBx password remains untouched.
  • CMOS clear – This un-provision option is not available in the MEBx. This option clears all values to their default values. If a PID/PPS is present, both values are lost. The MEBx password resets to the default value (admin). To invoke this option, you need to clear the CMOS (i.e. system board jumper).
What you need for reset to factoty default (easy to check that works, just test that password is admin afther the CMOS clear) is the CMOS clear.
To perform this you need to remove the keyboard and under the keyboard you can find the coin battery, unplug it form motherboard, wait for 8 minutes (at least I tested with 8 minutes) and it works. Note that this will clear all your CMOS so if in the setup is something special write it before the CMOS clear to restore later to the dessired value.
Rgds
Marcos Manzano
Thanks for the response. I couldn't find any documentation on Dell's support site about where to reset the CMOS.
Trevor
