Community
cancel
Showing results for
Search instead for
Did you mean:
CScot4
Difference between a brand name PC with vpro or without vpro
Hi all, just wondering what is the physical difference between a Dell optiplex computer with vpro and one exactly the same spec but without vpro.
When purchasing a Dell optiplex you can choose to have it with vpro or without. If you choose with it will add ~$40 to the build.
I am wondering what is this ~$40 paying for?
In the build the CPU is the exact same model i5-7500 that has vpro support bult in. So the CPU is not getting changed when you select the PC to come with vpro.
So what am I paying for? Is it a AMT chip that gets added to the motherboard when you selct the pc to come with vpro ?
or
Is it paying Dell to simply enable vpro via software?
thanks
crizz
MichaelA_Intel
crizz11
Hi Crizz,
Thanks for posting your question and I can see why you would ask. Intel vPro is a technology that enables specific capabilities. Here's a slide that shows some detail:
There is also a video available that provides more information about vPro. The link is here:
https://vimeo.com/219154762 The Intel vPro Platform_1080p_FULL on Vimeo
If you don't want to watch the whole thing, skip to 3:00 minutes.
If I understand your question:
vPro would be something that is not enabled via software.
Hope this helps.
Michael
