The documentation mentioned that with IMC SCCM integration, a deployment task with Wake on LAN enabled would trigger an AMT power on action on a device collection automatically.
Is this the case? Thanks.
Hi Ariel,
Thank you so much for contacting us about this concern.
Yes, that is correct.
You need to configure and enable the option when you are configuring the profile.
Emeth O.
Hi Ariel,
I am following up your thread in order to verify if there is any other question in order to asisst you with. If so, please do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
I was able to confirm that it works as intended on the SCCM server. But Is IMC SCCM integration supposed to work on a remote SCCM console? When I try to install it on a workstation with the SCCM console installed, there is no option to install the integration component.
Hi Ariel,
Let me check the information with an upper level department.
However, did you already check this information with Microsoft?
As soon as I will have more details on this I will get back to you.
Regards.
Emeth O.
Hi Ariel,
I was doing some research in my end and I found that It currently on works on the primary SCCM console. Should be fixed in an upcoming release.
Emeth O.
Hi Ariel,
I would like to know if there is anything else I can assist you with? If so, please do not hesitate and let me know and I will be more than happy to help you.
Emeth O.
Hi Ariel,
I was reviewing this thread and I have not seen any activity from your end. I am going to proceed and close this. If you have any other question please do not hesitate and contact us back and we will be more than happy to assist you.
Emeth O.
Topic Options
