Intel vPro® Platform
2835 Discussions
Does the Q8300 support Virtualization Technology
Yes the Q8300 supports VT. When you say you can't get it to work, what exactly are you trying to do to make it work?
VT isn't typically a stand-alone technology, you usually require 3rd party software that is written to take advantage of the specific hardware enhancements that VT offers. For reference - http://www.intel.com/technology/virtualization/ http://www.intel.com/technology/virtualization/
Jeff
I don't think the q8300 supports VT.
If you look at the chart Intel VT is not available on 2 CPU's: Q8200 and Q8300.
Or am I missing something?
Meanwhile the table was updated.
Jan
I am none too happy with Intel as I just purchased a Q8200 after reading intels website whcih said all Quad core processors support VT??
Very dissapointing that Intel can't provide accurate tech specs for their products
Dissapointment asside (there is always ebay for unwanted parts) I would like to know for sure that my Intel DG45ID motherboard will support VT before I upgrade the processor? I can't see any virtualisation settings in the BIOS but since my Q8200 doesn't have VT I'm really not sure?
No, it's not.
I received the following reply from Intel:
Hello Jan,
Thank you for your patience.
Indeed, the Intel(R) Core(TM) 2 Quad processor Q8300 does not support Intel(R) Virtualization Technology. We will update the information in pur website as soon as possible.
Please do not hesitate to contact us again if you need further assistance.
Sincerely,
Cindy J.
Intel Technical Support
Fine, but I'm stuck with my Q8300 now
I filled it their survey and asked to replace my processor, as I bought this processor after I checked on their website, to use with Intel VT.
Let's wait and see how service-minded Intel is.
Jan
I don't know much about these things. Does this mean I will or will not be able to modify my current Q8300 to get VT support?
Q8300 (SLB5W) when launched never supported Intel(R) Virtualization Technology.(VT)
The SLGUR which was recently released does support VT.
You will need a processor that supports VT in additional to the chipset and BIOS.
See the following: http://www.intel.com/support/processors/sb/CS-030729.htm http://www.intel.com/support/processors/sb/CS-030729.htm
And check with http://processorfinder.intel.com/List.aspx?ProcFam=2774&sSpec=&OrdCode http://processorfinder.intel.com/List.aspx?ProcFam=2774&sSpec=&OrdCode=
I am afraid the only option you have is to replace the cpu... i certainly cant be flashed like a bios.
Im having the same problem... I actually couldnt belive that my old Core 2 Duo supported it and year newer quad wouldnt and I certainly woundt have bought it if I knew...
DId you ever hear back about this? I made the same assumption that VT would be supported after reading it on their website. Did they replace the CPU with a different one?
My Q8300 in a DELL Inspiron 545 (bought in Dec. 2009) does support VT-x.
http://ark.intel.com/Product.aspx?id=39107# specs
You can test yours with the "Microsoft Hardware-Assisted Virtualization Detection Tool".
http://www.microsoft.com/downloads/details.aspx?FamilyID=0ee2a17f-8538-4619-8d1c-05d27e11adb2&displaylang=en
Martin
