Intel vPro® Platform
3067 Discussions
EMA Install package - 1.8.1
AV1
Hello!
Is there a location for a previous version of EMA. Specifically version 1.8.1. It appears that the default download location at downloadmirror.intel.com/646990 points to the latest 1.9 version.
Thanks!
JoseH_Intel
Hello AV1,
Thank you for joining the community
Usually, when there is a latest version of the Intel EMA the previous ones are no longer available. Since version 1.9 has been released already, v1.8.1 is not available anymore. Is there any reason why you need that particular version?
Jose A.
AV1
Thanks for the reply Jose!
The reason we are looking for earlier versions is that we have some environments that are still using an earlier version and need to have consistency in versions across environments. It takes a little while to get all environments on the same version (which we intend to do, but can't be done immediately). While we can install previous versions with a copy of the exe manually, this will however break our automated infra scripts.
Is there an archive location which we can point to for specific older versions?
Thanks !!
JoseH_Intel
Hello AV1,
Let me check if possible to get this previous version of EMA.
Jose A.
MIGUEL_C_Intel
Hello, AV1,
I sent you a private email with the zip file of the Intel® EMA software.
Miguel C.
MIGUEL_C_Intel
Hello, AV1,
I hope this email finds you well.
Have you been able to install the Intel® EMA version provided in the private message?
Please, keep in mind, older software versions have been removed for security purposes.
Miguel C.
AV1
Hello Miguel and a Happy New Year to you!
Thanks for sending the older version; and yes, we were able to use that.
Thanks so much for your help!!
MIGUEL_C_Intel
Hello, AV1,
We are glad to know the Intel® EMA software worked properly on your customization. Do not hesitate to reply if further assistance is necessary.
Miguel C.
