Intel vPro® Platform
3059 Discussions
EMA Server no longer connecting
KevSchu
EMA Version: 1.9
App Server: 2019 (Azure VM)
SQL Server: 2019 / 2019 (Azure VM)
For some reason our App server is no longer able to connect to the components.
1/11/2023 10:48:22 AM - War - Failed to connect pipe: EMAManageabilityServer
1/11/2023 10:48:23 AM - War - Failed to connect pipe: EMARecoveryServer
1/11/2023 10:48:26 AM - War - Failed to connect pipe: EMAAjaxServer
1/11/2023 10:48:34 AM - Inf - Performing web sync cleanup for: C:\inetpub\wwwroot
1/11/2023 10:48:34 AM - Inf - Web sync completed
1/11/2023 10:48:38 AM - Inf - Attempting to connect pipe: MeshManageabilityServer
1/11/2023 10:48:38 AM - Inf - Attempting to connect pipe: EmaRecoveryServer
1/11/2023 10:48:41 AM - Inf - Attempting to connect pipe: MeshAjaxServer
1/11/2023 10:48:44 AM - Err - Error: Event id: 101. Halted package: EMAAjaxServer, exitcode -532462766 (0xE0434352).
1/11/2023 10:48:44 AM - War - Failed to connect pipe: EMAManageabilityServer
1/11/2023 10:48:44 AM - Inf - Launched package: EMAAjaxServer.
1/11/2023 10:48:44 AM - Inf - Attempting to connect pipe: MeshAjaxServer
1/11/2023 10:48:44 AM - War - Failed to connect pipe: EMARecoveryServer
1/11/2023 10:48:47 AM - War - Failed to connect pipe: EMAAjaxServer
1/11/2023 10:48:48 AM - Err - Error: Event id: 836. Halted package: EMARecoveryServer, exitcode 0 (0x00000000).
1/11/2023 10:48:49 AM - Inf - Launched package: EMARecoveryServer.
1/11/2023 10:48:49 AM - Inf - Attempting to connect pipe: EmaRecoveryServer
I've tried restarting IIS, both App and SQL servers with no success.  uninstalled/reinstalled platform manager.
Victor_G_Intel
Hello KevSchu,
In order to continue further, please provide us the following logs in order to check this behavior further:
EMA logs from Server
[System drive]\Program File(x86)\Intel\Platform Manager\EmaLogs
Additionally, and for documentation purposes please provide the following:
  1. Were there any changes to the server before the issue started?
  2. Did this happen after an EMA update? If yes, please provide the previously installed version.
  3. Is the EMA server installed in a virtual machine or in a physical server?
  4. Please run these two commands: test-netconnection localhost -p 8000, test-netconnection localhost -p 443 and provide the outputs in your next response.
  5. Can you access the EMA server both Locally and remotely?
  6. Have you changed anything related to the certificates on this server?
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Hello KevSchu,
Please let me know if you still need further assistance.
Victor G.
KevSchu
sorry for the late response.  This miraculously started working again without having done anything.
Victor_G_Intel
Hello KevSchu,
Thank you for your response.
We are glad to know the issue got resolved on its own. Since the thread is now solved, we will proceed to close it.
Victor G.
