Intel vPro® Platform
3051 Discussions
EMA server installer error
DNLB
Error Log:
2021-01-15 18:40:29.6129|ERROR||16280|1|DisplayEvent - MeshServerInstaller.MainForm, EMAServerInstaller, Version=1.3.3.1, Culture=neutral, PublicKeyToken=57d11e903ea1ca2c - EVENT: Exception, Action: WebSettingsSyncing|backup previous machineKey, FileName: MainForm.cs, FunctionName: SyncWebSettings, ExceptionMsg: System.UnauthorizedAccessException: O acesso ao caminho 'C:\inetpub\wwwroot\web.config' foi negado.
em System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
em System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
em System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
em System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials, IWebProxy proxy, RequestCachePolicy cachePolicy)
em System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
em System.Xml.XmlTextReaderImpl.OpenUrlDelegate(Object xmlResolver)
em System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
em System.Threading.CompressedStack.Run(CompressedStack compressedStack, ContextCallback callback, Object state)
em System.Xml.XmlTextReaderImpl.OpenUrl()
em System.Xml.XmlTextReaderImpl.Read()
em System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
em System.Xml.XmlDocument.Load(XmlReader reader)
em System.Xml.XmlDocument.Load(String filename)
em MeshServerInstaller.MainForm.SyncWebSettings().
SergioS_Intel
Hello DNLB
Thank you for contacting Intel Customer Support.
EMA requires to be the “Default Website” on the IIS server and tries to overwrite the existing site. The error indicates that EMA is encountering permission issues overwriting this site. It is best to uninstall IIS completely and allow the EMA installer to install/config IIS with the proper settings.
Please follow these steps:
1. Open Server Manager
2. Click on Manage -> Remove Roles and Features
3. Click on Next (Before You Begin) -> Next (Server Selection)
4. Uncheck “Web Server (IIS)” in Server Roles
5. Click on Next -> Next -> Remove
6. Wait for the role removal to complete and reboot the server
7. Rerun the EMA installer
Please let us know in case you need more assistance.
Sergio S.
SergioS_Intel
Hello DNLB
We are following your question about the EMA installation, and we would like to know if the information provided was useful.
Sergio S.
SergioS_Intel
Hello DNLB,
We are following this thread and we would like to know if you still have the same installation errors after performing the troubleshooting steps that we provided you earlier.
We will be looking forward to your reply.
Sergio S.
SergioS_Intel
Hello DNLB,
Please contact us back in case you need further assistance.
Sergio S.
