Hello Guys,
In this version I can't see anymore legacy redirection mode option in AMT menu ctrl +P, only SOL, KVM, IDER.
Could you please help? Running on Centos 7.
Can someone please help?
diosim
Hi diosim,
Release 6.0 adds a fourth option: Legacy Redirection Mode, which also has a choice of enable or disable. When legacy redirection mode is enabled, the redirection listener is enabled after setup and configuration completes. This can ensure compatiblity with management consoles created to work with the legacy SMB mode and do not have a mechanism implemented to enable the listener remotely.
You can use Intel Manageability Commander to turn on the redirection listener remotely:
https://downloadcenter.intel.com/download/26375/Intel-Manageability-Commander Download Intel® Manageability Commander https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiJuICFkfjUAhWK64MKHTDsCFkQFggmMAA&url=https://downloadcenter.intel.com/download/26375/Intel-Manageability-Commander&usg=AFQjCNHVuh35vSHbaNnHzNqkW1x0K9j6cA
Alternatively, you can also use Mesh Commander:
http://www.meshcommander.com/meshcommander MeshCommander - Open Software Projects
Michael
Thanks for your answer.
I managed to use wsman for enabling the redirection, but why we are missing this option in this version?
Release 6 is from version 10 or 11?
