Intel vPro® Platform
3046 Discussions
Existing Intel EMA version detected. Update installation will be performed but I don't have a previous version installed.
MRoll12
I am trying to install Intel EMA for the first time, but it tells me that I have a previous version installed, but I don't. I unstall all sections of it, but the install still fails with same message.
MichaelA_Intel
Hi Mark,
An existing EMA install where none has ever taken place is something that I have not seen before. Is there a possibility that someone else might have tried installing EMA in your environment? Can you check the SQL database to see if there is an EMA DB that exists?
Michael
MichaelA_Intel
Hi Mark,
Following up with you on this. Were you able to check the SQL database?
Michael
MichaelA_Intel
Hi Mark,
Just checking on this as I haven't seen a response.
Michael
MichaelA_Intel
I haven't received a response on this, so I will go ahead and close out this case.
Michael
