Intel vPro® Platform
2761 Discussions
Failed to call CheckCertificate provider method (oobmgmt.log)
I am getting an error in my oobmgmt.log on a unprovisioned AMT 2.5.0 ConfigMgr client that says "Failed to call CheckCertificate provider method, 80041001".
Any ideas what the source of this issue could be?
Trevor Sullivan
Systems Engineer
OfficeMax Corporation
Here is the output from MEinfowin.
Intel(R) MEInfo Win Version: 2.5.0.1032
BIOS Version: 68MCU Ver. F.15
Intel(R) AMT code versions:
Flash: 2.5.0
Netstack: 2.5.0
Apps: 2.5.0
Intel(R) AMT: 2.5.0
Sku: 12
VendorID: 8086
Build Number: 1084
Recovery Version: 2.5.0
Recovery Build Num: 1084
Legacy Mode: False
Link status: Link down
Cryptography fuse: Enabled
Flash protection: Enabled
Last reset reason: Firmware Reset
Setup and Configuration: Not started
BIOS Mode: Post Boot
Dedicated Mac Address: 00-16-d4-f0-f2-59
Host Mac Address: 00-16-d4-f0-f2-58
FWU Override Counter: Never
FWU Override Qualifier: Always
FW on Flash Desc Override: Disable
Kedron Driver Version: 11.1.0.86
Kedron HW Version: 0.0.40
UNS Version: 2.5.7.1083
LMS Version: 2.5.10.1083
HECI Version: 2.5.29.1090
FYI, this error was showing up on an Intel-provided HP Compaq 6910p, which appears to have an OEM build of Vista on it. It has a lot of customized local policy settings in Windows that may be interfering with things, so I am going to reload it with our standard build.
I just wanted to document this error message as something that may come up ...
Trevor Sullivan
Systems Engineer
The CheckCertificate provider method being referred to appears to be a WMI method on the CCM_PrvsMethodProvider class in the root\ccm WMI namespace. This is a static method and it takes a single string parameter, which I believe is the root certificate hash to be matched in the firmware.
I'm not sure why this would have been failing, but perhaps for some reason, it didn't like the hash it was fed?
Trevor Sullivan
Systems Engineer
Hmmm, well I upgraded the system to AMT 2.6.1, and loaded Windows 7 Beta Build 7000 on it, and I'm still getting the same error.
This message is also being logged just before the original error I posted:
<![LOG[Raising event:<p>
[SMS_CodePage(437), SMS_LocaleID(1033)]
instance of SMS_OOBMgmt_StartConfig_Failure
ClientID = "GUID:0BF82776-D18D-4F30-AC91-FBA6D47F0CDC";
DateTime = "20090217171109.097000+000";
ErrorCode = "1";
FailureCategory = "Failed to enumerate certificate hash, please check if the BIOS contains valid certificates.";
MachineName = "vproclient";
ProcessID = 1964;
SiteCode = "123";
ThreadID = 336;
]LOG]!>
Here's the latest MEinfowin after upgrading it:
Flash: 2.6.1
Netstack: 2.6.1
Apps: 2.6.1
Intel(R) AMT: 2.6.1
Sku: 12
VendorID: 8086
Build Number: 1030
Recovery Version: 2.6.1
Recovery Build Num: 1030
Legacy Mode: False
Last reset reason: Power up
Kedron Driver Version: 12.1.0.14
UNS Version: 2.6.8.1030
LMS Version: 2.6.11.1030
HECI Version: 2.6.30.1014
Trevor Sullivan
Systems Engineer
Consider this Powershell output from my Windows Vista Enterprise SP1-based Dell Latitude D630C running AMT 2.6.2:
PS C:\Users\User> $Prvs = [wmiclass]"root\ccm:CCM_PrvsMethodProvider"
PS C:\Users\User> $Prvs.CheckCertificate("test")
__GENUS : 2
__CLASS : __PARAMETERS
__SUPERCLASS :
__DYNASTY : __PARAMETERS
__RELPATH :
__PROPERTY_COUNT : 4
__DERIVATION : {}
__SERVER :
__NAMESPACE :
__PATH :
dvcCert : test
ErrorCode : 1
ErrorMsg : None certificate is valid between device and server certific
ate hash.
ReturnValue : 1
.... and this output from the HP Compaq 6910p running AMT 2.6.1:
PS C:\Users\i081225> $Prvs = [wmiclass]"root\ccm:CCM_PrvsMethodProvider"
PS C:\Users\i081225> $Prvs.CheckCertificate("test")
__GENUS : 2
__SUPERCLASS :
__RELPATH :
__DERIVATION : {}
__SERVER :
__NAMESPACE :
__PATH :
dvcCert : test
ErrorCode : 1
ErrorMsg : Failed to enumerate certificate hash, please check if the BI  OS contains valid certificates.
ReturnValue : 1
Trevor Sullivan
Systems Engineer
And then again (on the Latitude D630C), when provided with a correct / valid / trusted root certificate hash:
PS C:\Users\i081225> $Prvs.CheckCertificate("74 2c 31 92 e6 07 e4 24 eb 45 49 54
2b e1 bb c5 3e 61 74 e2".Replace(" ",""))
__GENUS : 2
__SUPERCLASS :
__RELPATH :
__DERIVATION : {}
__SERVER :
__NAMESPACE :
__PATH :
dvcCert : 742c3192e607e424eb4549542be1bbc53e6174e2
ErrorCode : 0
ErrorMsg :
ReturnValue : 0
Trevor Sullivan
Systems Engineer
Well, this issue is apparently a known problem with AMT 2.5 to AMT 2.6 upgrades. The certificate hashes are actually missing from the firmware, which is causing this method on the ConfigMgr client to fail.
http://communities.intel.com/thread/2031?tstart=0 http://communities.intel.com/thread/2031?tstart=0
Here is some Powershell code you can run to enumerate embedded hashes via the HECI driver interface:
<!--[if gte mso 9]> Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--><!--[if gte mso 9]> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium ...
I have the exact same issue on a Dell Optiplex 755. It was AMT firmware 3.0 upgraded to 3.2.2. We are using an internal certificate, and have keyed in the hash manually. Every time the SCCM client tries to provision the system in-band, I get the exact same error. I have tried everything I can think of, but the error remains.
I can supply log files, exact error quotes, anything necesssary. This has been driving me crazy for over a week, any suggestions are welcome.
John,
Can you try running the Powershell code I posted? For what it's worth, I've upgraded a bunch of Dell Optiplex 755's from 3.0 to 3.2.1 or 3.2.2, and haven't seen this issue on them.
Let me know if it outputs anything (take a screenshot of your Powershell instance).
Trevor Sullivan
Systems Engineer
Steven_D_Intel1
When you key the hash into the MEBX on the DELL, make sure it is the hash from the root certificate of your internal PKI and not the hash from the provisioning certificate itself
This may be why you are seeing this error
May also be worth checking that SCCM did actually accept your provisioning certificate when you configured the Out of Band Management Component. I have seen couple of examples where you specify the certificate, it appears like SCCM accepted it, and then when you look in AMTOPMGR.LOG file you find SCCM rejected it (wrong domain, missing OID or OU...)
Hope this helps
Hi Trevor,
Thanks for responding. I have installed powershell, but I have absolutely no experience with it, can you point me to the steps required to run the command you posted?
In the meantime, here's the output of MEInfoWin
C:\ME>meinfowin
BIOS Version: A12
Flash: 3.2.2
Netstack: 3.2.2
Apps: 3.2.2
Intel(R) AMT: 3.2.2
Sku: 12
VendorID: 8086
Build Number: 1033
Recovery Version: 3.2.2
Recovery Build Num: 1033
Legacy Mode: False
Link status: Link up
Setup and Configuration: In process
Dedicated Mac Address: 00-1a-a0-e6-5c-d0
Host Mac Address: 00-1a-a0-e6-5c-ce
FWU Override Counter: Always
Kedron Driver Version: Not Available
Kedron HW Version: Not Available
UNS Version: 3.0.4.1089
LMS Version: 3.0.10.1089
HECI Version: 3.0.30.1086
This is the relevant portion of the OOBmgmt log
Raising event:
[SMS_CodePage(850), SMS_LocaleID(4105)]
ErrorCode = "1";
FailureCategory = "None certificate is valid between device and server certificate hash.";
MachineName = "XXX";
ProcessID = 180;
SiteCode = "AAA";
ThreadID = 4092;
We have manually added the hash several times and have followed the technet articles on how to do so. The only thing I can think of is the name of the hash in the BIOS, we have typically left it blank, could that have any effect?
Thanks!!
John
John,
Open a Powershell instance, and simply paste in the code I provided.
Alternatively, download the free http://www.powergui.org Quest PowerGUI tool, then save the code to a .ps1 file, and hit the "Play" button to execute it.
Trevor Sullivan
Systems Engineer
Sdavies, Thanks for responding.
Originally we made the mistake of keying in the hash from the provisionsing certificate, but a few days ago I discovered that and we them began entering the hash from the root CA instead. In the amtpopmgr log, I get entries like this:
Found new provision server certificate with hash
Get ROOT HASH of provision server
Is the ROOT HASH value the same as the one that should be in the BIOS of the client PC?
I also get an error whenever I try to discover OOB controllers on the collection:
AMT Discovery Worker: Wakes up to process instruction files SMS_AMT_OPERATION_MANAGER 2/27/2009 2:03:16 PM 10664 (0x29A8)
CAMTDiscoveryWSMan::DoDetectAMTVersion: recv failed: 10054 SMS_AMT_OPERATION_MANAGER 2/27/2009 2:03:16 PM 11768 (0x2DF8)
Server unexpectedly disconnected when TLS handshaking. SMS_AMT_OPERATION_MANAGER 2/27/2009 2:03:16 PM 11768 (0x2DF8)
**** Error 0x3b2b904 returned by ApplyControlToken SMS_AMT_OPERATION_MANAGER 2/27/2009 2:03:16 PM 11768 (0x2DF8)
AMT Discovery Worker: Wait 20 seconds... SMS_AMT_OPERATION_MANAGER 2/27/2009 2:03:16 PM 10664 (0x29A8)
session params ::16992 , 111001 SMS_AMT_OPERATION_MANAGER 2/27/2009 2:03:16 PM 11768 (0x2DF8)
ERROR: Invoke(get) failed: 80020009argNum = 0 SMS_AMT_OPERATION_MANAGER 2/27/2009 2:03:16 PM 11768 (0x2DF8)
Description: The I/O operation has been aborted because of either a thread exit or an application request. SMS_AMT_OPERATION_MANAGER 2/27/2009 2:03:16 PM 11768 (0x2DF8)
Error: Failed to get AMT_SetupAndConfigurationService instance. SMS_AMT_OPERATION_MANAGER 2/27/2009 2:03:16 PM 11768 (0x2DF8)
session params : 16992 , 111001 SMS_AMT_OPERATION_MANAGER 2/27/2009 2:03:16 PM 11768 (0x2DF8)
I was ignoring this for the time being because I think it refers to OOB provisioning, and we're trying to get around that.
Thanks!
Hi Trevor,
I ran the powershell command, and it comes back with a match for the hash we entered, but this has me thinking it's the wrong certificate hash we are entering. Because of the structure of this organization, I'm having difficulty getting direct access to the root CA server. Is there anyway to get the hash I'm looking for from the certificates mmc on the provisioning server? Or is it in the amtpopmgr log file as shown in the C/P in my previous post?
Thanks!
Open the properties on your provisioning certificate, go to the certificate chain, open the root CA's certificate, go to the details tab, and find the Thumbprint.
Here is a quick demonstration: http://blip.tv/file/1823217 http://blip.tv/file/1823217
Trevor Sullivan
Systems Engineer
I did as you suggested, and as it turns out, we were entering the wrong hash. For future information, the hash we needed to use was listed in the amtpopmgr log file in the entry
Get ROOT HASH of provision server .
After entering the correct hash, the oobmgmt log on the client now shows it was provisioned succesfully. I'm going to wait to see the change on the object in the collection before I get to excited, but this defnitely looks good. I'll keep you posted and thanks to both of you for the help.
John
John,
I'd really recommend purchasing an SSL certificate for the purposes of AMT provisioning. When you consider that you can get one from Godaddy for only $90 per year, it's really worth it to avoid having to touch each and every machine.
Trevor Sullivan
Systems Engineer
Hi Trevor,
I've already made that recommendation. Once I get this lab setup running, I'll leave it to them to decide how to proceed.
In the meantime, even though the oobmgmt log shows the client was succesfully configured, it still shows as "detected" in the collection. The amtpopmgr log still shows the same errors as I had previously posted. Am I missing something? Once it has been configured in-band, should it not automatically change to provisioned after the system has had a chance to process it? The collection is set to automatically provision computers, but as this one is still just detected, I assume it hasn't tried to provision it yet.
Any suggestions are greatly appreciated.
John
John,
I'd recommend installing http://support.microsoft.com/kb/960804 Microsoft KB 960804, which is an update rollup for out-of-band management in ConfigMgr. See if this has any effect on the issue you're having.
FYI, sometimes you have to do "Update Collection Membership" (or even run a separate Management Controller discovery task), instead of simply refreshing the collection in order to get the AMT provisioning status to change.
If you have an AMT client that's stuck as "Detected" I believe it's possible that ConfigMgr may have provisioned it in the past, but the resource was deleted from the database, and now it can't connect to it again. I believe that ConfigMgr uses digest authentication using a randomly generated password in its database, that is associated with the respective AMT client. If you delete the resource record for a provisioned AMT client, it will remain provisioned, but ConfigMgr won't be able to manage it any longer. Don't quote me on any of this though, because it's only based on what I have lightly observed over time.
Trevor Sullivan
Systems Engineer
I'll look into installing that rollup. In the meantime, I have updated and refreshed several times, and the client still shows as detected. During the course of troubleshooting, we changed the admin password in the oob component configuration, could that have any effect? We changed the password on the client machine as well. I'd change it back but unfortunately, the SCCM console enforces a strong password for that account, so it wont accept the default of "admin" anymore.
John
John,
If you changed the MEBx password manually on an AMT client, then you need to specify that password under the Provisioning Accounts tab of the OOB Component Configuration screen. During a provisioning attempt, ConfigMgr first tries any passwords specified in that area, then it tries the default password of "admin".
It's possible that this is the reason you are seeing Detected instead of Not Provisioned. If ConfigMgr can see an AMT device responding during a management controller discovery, but is unable to authenticate to it with the default remote MEBx password, then logically, it would probably show Detected. This isn't an exact scenario I've tested though, so don't quote me
The reason that I recommended purchasing an SSL certificate earlier, was because this would allow you to reset the MEBx back to factory defaults (pull the CMOS battery and disconnect power), and not ever have to login to the MEBx locally (to enter your internal root CA hash). This is more or less a "best practice" because it takes the entire issue of a changed MEBx password completely out of the equation.
Trevor Sullivan
Systems Engineer
