Intel vPro® Platform
3072 Discussions
[Filter: smut] evenlin1's post body matched "xxx", board "vpro-platform".
evenlin1
Post Subject: EMA CIRA connect fail
Post Body:
I’ve set up a local EMA server and trying to connect a DUT to it for AMT testing. According to the documentation, I was able to provision the DUT successfully via EMA, but it fails to connect to CIRA.
Using the EMAConfigTool, I found that the AMT IP address was not assigned—it's also showing as 0.0.0.0 in the AMT Web UI.
*** ME Information ***
Version: 18.1.18.2616
SKU: Intel(R) Full AMT Manageability
State: Provisioned
Control Mode: Client
Driver Installed: True
Driver Version: 2512.7.3.0
PKI DNS Suffix: xxx.com
LMS State: Running
*** ME Capabilities ***
AMT in Enterprise Mode: True
TLS Enabled: True
HW Crypto Enabled: True
Current Provisioning state: POST_PROVISIONING_STATE
NetworkInterface Enabled: True
SOL Enabled: True
IDER Enabled: True
FWUpdate Enabled: False
LinkIsUp state: True
KVM Enabled: True
RSE Enabled: False
*** CIRA Information ***
CIRA Server: laptop-xxxxxxxx.com
CIRA Connection Status: CONNECTING
CIRA Connection Trigger: TRIGGER_PERIODIC
*** ME Wired Network Information ***
Wired Interface Enabled: True
Link Status: Up
IP Address: 0.0.0.0
MAC Address: 34:12:67:45:12:90
DHCP Enabled: True
DHCP Mode: Passive
DNS Suffix (from OS): Not Found
*** ME Wireless Network Information ***
Wireless Interface Enabled: True
Link Status: Down
IP Address: 0.0.0.0
MAC Address: A8:59:5F:24:BD:87
DHCP Enabled: True
DHCP Mode: Passive
However, if I manually provision the DUT by MEBX not EMA, the AMT IP will get assigned correctly and can access DUT via the AMT Web UI. Despite this, the CIRA connection still fails in EMA.
Could you help me figure out what’s causing the issue? Thank you!
Body text "xxx" matched filter pattern "xxx".
Post by User[id=207157,login=evenlin1] was rejected for the following end-user facing error(s):
  • The message body contains Crypto, which is not permitted in this community. Please remove this content before sending your post.
vij1
Hello evenlin1,
Thank you for reaching out.
We’d like to inform you that we will be continuing our response in a different thread to keep the discussion organized. You can follow the conversation at the link below:
https://community.intel.com/t5/Intel-vPro-Platform/EMA-CIRA-connect-fail/m-p/1698335#M12973
Please feel free to reply there if you have any further questions or updates.
Vijay N
Intel Customer Support
