Intel vPro® Platform
3062 Discussions
HP Mini Desktop PCs and INTEL ME / vPRO - how to enable?
iam-user3324
I would like to remote "Power On" (like WOL)  a HP Mini  400 or 600 Series Gen9  or Gen10 PC.
Initial SETUP:  (afaik it is only required to to set access credentials) (maybe it is also required to intial enable it in BIOS via F10)
I observed that STRG+P (?) during boot-procedure doesn´t open the INTEL ME (vpro) Management Setup.
I assume that INTEL ME is only possilbe, if the INTEL sticker is on the chassis.
But is difficult, STRG+P not allways works.
Do you know the clou / how to make it easier?
Thx/ Best Regards
vij1
Hello iam-user3324,
Greetings!
Thank you for your response. To assist you further, kindly share the following logs:
SSU Logs
Please refer to the guide at the link below to generate and share the SSU logs:
Generating SSU Logs https://www.intel.com/content/www/us/en/support/articles/000057926/memory-and-storage.html
ECT Logs
We also request you to share the Intel® EMA Configuration Tool (ECT) logs from both machines.
Steps to Generate ECT Logs:
Download the Intel® EMA Configuration Tool (ECT):
Download ECT: https://www.intel.com/content/www/us/en/download/19805/30485/intel-endpoint-management-assistant-configuration-tool-intel-ema-configuration-tool.html
  1. Installation:
  • Download and unzip the tool.
  • Double-click the .msi file and follow the prompts to install it.
  1. Run the Tool:
  • Open a Command Prompt as Administrator (or Windows PowerShell*).
  • Navigate to the installation folder (default path: C:\Program Files (x86)\Intel\EMAConfigTool).
  • Run the following command:
  • EMAConfigTool.exe --verbose
Please share the logs generated after following these steps for both machines.
Vijay N.
Intel Customer Support.
vij1
Hello iam-user3324,
Greetings!
We are following up to find out if you were able to complete the actions, we previously recommended. Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Vijay N.
intel.com/vPro
vij1
Hello iam-user3324,
Greetings!
If further assistance is necessary, do not hesitate to reply.
Vijay N
