Intel vPro® Platform
2857 Discussions
Hardware-assisted virtualization is not enabled on D975XBX
PCran
Hello.
I try to make work Windows Virtual PC (into a Win7 Pro 64bit) with a D975XBX board with E6700 intel cpu.
i had already activate the VT into the Bios but, no chance, the hardware assisted virtualization detection tool still showing me tha my settings are not enable on this computer...anny ideas to help me to make this windows xp mode work into my win 7?
help will be much more appreciate.
There are two settings that should be set for virtualization to work, you menton you enabled Intel (r) Virtualization Technology, did you also enable VT-d. I am searching for the right contact to get a look at the platforms BIOS so I can confirm where these two elemets are located on that bios - I typically see them listed under the CPU setup section.
i have core i7 processor & i select intel DX58SO for server 2003 & xp OS for media work please me for select best mother board .....
I am not sure windows server 2003 & windows xp in this Hardware core i7 & DX58SO support or not..please help me...
PCran
i suggest you to install win7 64bit and not win xp, or winserver 2008, for better reliability and security...
Dear i have core i7 processor & i select intel DX58SO motherboard for server 2003 & windows xp also i am working in graphics please help me for select motherboard for server 2003 or xp for media work
Hi
Did you get an answer? How did you enable the VT finally?
