Intel vPro® Platform
3067 Discussions
How can I check a remote computer's power state with Intel EMA powershell? I'm using 1.10
YasserA
Dear Sir/Madam,
How is this achievable with PowerShell?
I've looked through the swagger API - but can't seem to find it.
Please help?
Kindest regards
Yasser
Victor_G_Intel
Hello YasserA,
Thank you so much for contacting Intel customer support,
In regard to your question, the only options that we have for power shell scripts in reference to an endpoint’s power state are the ones below:
Set-IntelEMAEndpointPowerState: Sends a specified power command to an
 endpoint.
Set-IntelEMAEndpointPowerStateBulkFile: Sends a specified power command to a
 list of endpoints managed by Intel(R) EMA.
Both commands are meant to be used to change a computer’s power state to either reset it, reboot it or wake up an endpoint.
Victor G.
Intel Technical Support Technician
Jimmy_Wai_Intel
Hi YasserA,
You can use the Endpoint details API /api/latest/endpoints/{endpointId} to get the power status. Power status is part of the information returned from the API.
Jimmy Wai
Technical Sales Specialist, Intel
YasserA
Dear Victor,
Many thanks for the quick reply!
Intel SCS powershell provided much more functionality - is there any development going on to get power state querying available in PowerShell?
also - if not PowerShell - is this power state querying functionality available via Javascript or any other language?
Kindest regards
Yasser
YasserA
Dear Jimmy,
Many thanks for your quick response!
I noticed in the sample script (Get-IntelEMAEndpointFullDetails.ps1) it has the following:
        0 {$endpointResult.PowerState = [string]$endpointResult.PowerState + " (On)"}
        1 {$endpointResult.PowerState = [string]$endpointResult.PowerState + " (On)"}
        2 {$endpointResult.PowerState = [string]$endpointResult.PowerState + " (Off)"}
        3 {$endpointResult.PowerState = [string]$endpointResult.PowerState + " (Off)"}
        4 {$endpointResult.PowerState = [string]$endpointResult.PowerState + " (Sleep)"}
        5 {$endpointResult.PowerState = [string]$endpointResult.PowerState + " (Hibernate)"}
        6 {$endpointResult.PowerState = [string]$endpointResult.PowerState + " (On)"}
I couldn't find the details under endpoints in swagger - but I need to know what the 3 On states mean? and the 2 Off states? Can you please shed some more light?
Is one of them Standby? How do they correlate with the S0 to S5 states - etc?
Many thanks - all help is appreciated!
Kindest regards
Yasser
Victor_G_Intel
Hello YasserA,
Thank you for your response.
Please let me review this information internally, and kindly wait for an update.
Once we have more information to share, we will post it on this thread.
Victor G.
Victor_G_Intel
Hello YasserA,
Thank you for your patience.
You can use the following command:
In Endpoint Details you will find the following:
"PowerState": "0 (On)",
"PowerStateUpdate": "2023-05-03T03:19:45Z",
"IsConnected": true,
"IsCiraConnected": true,
Victor G.
JoseH_Intel
Hello YasserA,
I am just following up to double-check if you were able to gather the requested information. Otherwise, let us know if you require more time to accomplish this.
Jose A.
Victor_G_Intel
Hello YasserA,
We have not heard back from you.
Victor G.
