Intel vPro® Platform
2782 Discussions
How to use INTEL-SA-00075 Detection and Mitigation Tool Guide 1.0.2.116
JChan106
I run "intel-SA-00075-console.exe -DisableLMS", it does not have any return.
How can I know whether LMS disable or not in script?
Do i need to use other command to verify the result?
Some user report that when they run detection tool, the tool show " the toll was unable to detect ME or SMBIOS information to assess vulnerability".
What does ti means?
MichaelA_Intel
joeslchan
Hi Joeslchan,
Can you provide the CPU models of the systems that you are referring to? Do you know if they are vPro enabled?
If you run the detection tool again without the -DisableLMS the tool will write to the registry. You can see the results here:
32-bit location - HKEY_LOCAL_MACHINE\SOFTWARE\Intel\Setup and Configuration Software\INTEL-SA-00075 Discovery Tool\ME Information
64-bit location - HKEY_LOCAL_MACHINE\SOFTWARE\WoW6432node\Intel\Setup and Configuration Software\INTEL-SA-00075 Discovery Tool\ME Information
Michael
JChan106
The PC information:
The INTEL-SA-00075 information
MichaelA_Intel
joeslchan
Hi Joeslchan,
Thank you for the information. Can you tell us what model Lenovo you are running the tool on? Secondly, can you send the other half of the screen shot? The ME information? Lastly, what language OS are you running?
Michael
JChan106
The PC's OS is Windows 7 Enterpriese 64bit
Model is 3392AV7 (Lenovo ThinkCentre M82 3392)
Chinese (Traditional) Hong Kong SAR
intel-SA-00075-console.exe will save the information at registry.
Where can i find the more information about the meaning of the registry key?
MichaelA_Intel
joeslchan
Hi joeslchan,
can you post a screen shot of the right side pane of the registry from this hive?
Michael
JChan106
MichaelA_Intel
joeslchan
Hi Joeslchan,
I have escalated this issue up to the developers and will provide an update when I hear back.
Michael
MichaelA_Intel
joeslchan
Hello again, I've been in contact with the developers and we need the following information from the registry:
Click on windows logo:
type regedit
traverse the tree to the following locations:
We need the values. You can provide a screen shot of the registry if it's easier.
MichaelA_Intel
joeslchan
Hi Joeslchan,
We're still waiting to hear back from you. In the meantime, we have released a newer version of the detection and mitigation tool. Please run and see if you get better results:
https://downloadcenter.intel.com/downloads/eula/26755/INTEL-SA-00075-Detection-and-Mitigation-Tool?httpDown=https://downloadmirror.intel.com/26755/eng/Intel-SA-00075%20Detection%20and%20Mitigation%20Tool.zip INTEL-SA-00075 Detection and Mitigation Tool
Michael
