Intel vPro® Platform
3056 讨论
Intel EMA Certificate Chaining Issue
RyomaFujiki
初学者
40,468 次查看
Hello.
I am in the process of setting up EMA in Admin Control Mode, but I am unable to provision AMT with TLS-PKI.
I can see the following error in the Platform Manager
Error Message: Unable to get activation certificate chain from the database.
I have tried the following article on this, but it did not resolve the issue.
https://www.intel.co.jp/content/www/jp/ja/support/articles/000090529/software/manageability-products.html
I can connect to CIRA without any problem.
The version of EMA is 1.7.1.
I am using GoDaddy's certificate.
If you know of any solutions, please let me know.
0 项奖励
48 回复数
Victor_G_Intel
24,006 次查看
Hello RyomaFujiki,
To further assist you, please provide the following:
1-For documentation purposes please provide us a picture of the error code received.
2-You mentioned that you were following the article: Intel® Endpoint Management Assistant (Intel® EMA) Version 1.7 Certificate Chaining Issue. Can you please confirm if you were able to follow all the steps included within it?
3-Can you please let us know if this is a new implementation or if this is being done on an already functional deployment?
4-How many systems are being affected?
5-Please share with us the AMT version being used.
6-Can you please share with us a picture of all the certificates being used with EMA?
Victor G.
0 项奖励
RyomaFujiki
初学者
23,991 次查看
Hello Victor G,
Thank you for your response.
Please check "1.ErrorMesssage.png" in the attached image.
I followed the steps in the article and verified that "ORDER BY [Certificate]" was entered in the specified location. Please check "2.Follow all the steps.png" in the attached image.
It is a new implementation; we have never been able to provision in Admin Control Mode.
Since this is a trial implementation, there are no systems affected.
The following are the versions. Please check "5.AMT_Version.png" in the attached image.
v12.0.40
v12.0.81
v12.0.49
Please check "6.CertficateChain.png" in the attached image.
Ryoma Fujiki
0 项奖励
Victor_G_Intel
23,968 次查看
Hello RyomaFujiki,
Thank you so much for your response.
To continue with our internal investigation, please provide the following:
We are going to need a picture/screenshot of the enhanced key usage and the certification path of your root certificate.
Victor G.
0 项奖励
RyomaFujiki
初学者
23,943 次查看
Hello Victor G,
I have attached the specified image.
Please take a moment to review it.
Ryoma Fujiki
0 项奖励
Victor_G_Intel
23,909 次查看
Hello RyomaFujiki,
To continue further we need to verify your PKI certificate; therefore, please provide two pictures just like the one attached to this message, one showing the certification path and one showing the enhanced key usage.
Victor G.
0 项奖励
RyomaFujiki
初学者
23,887 次查看
Hello Victor G,
I have attached the specified image again.
Thank you for your confirmation.
Ryoma Fujiki
0 项奖励
Victor_G_Intel
23,872 次查看
Hello RyomaFujiki,
Please let me review this information internally, and kindly wait for an update.
Once we have more information to share, we will post it on this thread.
Victor G.
0 项奖励
Victor_G_Intel
23,853 次查看
Hello RyomaFujiki,
Thank you so much for your patience.
Based on our investigation this seems to be a certificate issue; however, we need to verify a few things before jumping to any conclusions. To continue, we can see that the certificate you have is issued to ematest.f5.si; however, what domain are the endpoints on? The domain should match the certificate in order for provisioning to work.
Additionally, please send us a screenshot of what exactly appears in MEBx BIOS for the following fields:  Option 15 and DNS Suffix.
Victor G.
0 项奖励
RyomaFujiki
初学者
23,824 次查看
Hello Victor G,
Please check it for us.
We did not have Option15 configured.
But even if we did set it up, we could not provision with ACM in version 1.7.1.
However, when we set it up with version 1.6.1, we were able to provision it with ACM.
We want to use OCR so we need to be on 1.7.1.
Ryoma Fujiki
0 项奖励
Victor_G_Intel
23,816 次查看
Hello RyomaFujiki,
Victor G.
0 项奖励
Victor_G_Intel
23,723 次查看
Hello RyomaFujiki,
Thank you for your patience.
Based on our investigation, it doesn't look like the .si domain that you are trying to use is supported by AMT, in other words, it isn't going to work. Therefore, please see the Intel AMT Implementation and Ref Guide for the domain details and let us know if it is within your possibilities to try to use a validated domain.
https://software.intel.com/sites/manageability/AMT_Implementation_and_Reference_Guide/default.htm?turl=WordDocuments%2Fpkicertificateverificationmethods.htm
Additionally, since you guys mentioned not having this problem with EMA 1.6 can you please confirm if the same certificate was used with EMA 1.6 is the same one used now with EMA 1.7?
Victor G.
0 项奖励
RyomaFujiki
初学者
23,713 次查看
Hello Victor G,
It certainly seems that .si domains are not supported.
However, we are able to make ACM connections with EMA 1.6.1 using the same certificates that we use with EMA 1.7.1.
Is there any other possible cause?
Ryoma Fujiki
0 项奖励
Victor_G_Intel
23,706 次查看
Hello RyomaFujiki,
Please allow us some more time to investigate other possibilities with the information we have at the moment. As soon as possible we will be reaching you back.
Victor G.
0 项奖励
Victor_G_Intel
23,684 次查看
Hello RyomaFujiki,
In order to move forward with this situation and so we can understand better the type of support that you guys are looking for, can you please clarify exactly what you guys are trying to achieve on your end?
1-Additionally, we would like to know if you guys change the ematest portion of the DNS?
Note: Even capitalization or lack thereof will make a difference (i.e. EMAtest vs ematest) Those are different according to EMA, it is case sensitive.
2-Please capture a screenshot of your EMA WebUI setting page with the cert chain on it. In addition, please share a screenshot of your cert chain in the Cert store.
3-For further analysis, we will be requiring you to provide the manageability logs from your end. In order to get the logs out please look at them at the following locations:
Manageability logs
EMA logs from Server
[System drive]\Program File(x86)\Intel\Platform Manager\EmaLogs
EMA log from the endpoint:
[System drive]\Program Files\Intel\EMA Agent\EMAagentlog
Installation log:
<installer Directory>/EMALog-Intel EMAInstaller.txt
Victor G.
0 项奖励
RyomaFujiki
初学者
23,674 次查看
Hello Victor G,
We do not plan to change the domain name (ematest).
We have prepared it. Please confirm.
It has been prepared. Please confirm.
EmaAgent.log was obtained from PC name: DESKTOP-49CB8C7.
0 项奖励
SergioS_Intel
主持人
23,667 次查看
Hello RyomaFujiki,
Thank you for waiting for our updates.
Please help us by providing some additional information:
1. Are you trying to create a self-signed cert based off of a public DDNS service?
2. Did you change the EMA test portion of the DNS?
3. Please provide us a screenshot of your EMA WebUI setting page with the cert chain on it.
4. Please share a screenshot of your cert chain in the Cert store.
5. Finally, please share with us the manageability logs.
Looking forward to your updates.
Sergio S.
0 项奖励
RyomaFujiki
初学者
23,644 次查看
Hello Sergio S,
In setting up EMA, we do not create self-signed certificates.
We have never changed the DNS (ematest.f5.si).
Please check "3.EMA_WebUI_Setting.png" in the attached image.
Please check "4.CertChain.png" in the attached image.
Please check "5.ManagebilityLog.png" and "5.ManageabilityLog.zip" in the attached File.
Ryoma Fujiki
0 项奖励
Victor_G_Intel
23,636 次查看
Hello RyomaFujiki,
Thank you for both of your latest responses.
Please allow us some more time to continue with our investigation. We will let you know once we have any news on our end.
Victor G.
0 项奖励
Victor_G_Intel
23,620 次查看
Hello RyomaFujiki,
Based on the information that you provided it seems that when you are exporting the certificate is not being exported correctly, once you have exported the certificate correctly, on the endpoint the certificate chain should end up having three lines one for the PKI certificate, one for the secure certificate and the last one for the root certificate (Please see attached image for an example).
On the link below on page 23 and forward you can find the steps that you need to take in order to successfully export the certificate.
https://www.intel.com/content/dam/support/us/en/documents/software/software-applications/how_to_purchase_and_install_godaddy_certificates_for_setup_and_configuration.pdf
Victor G.
0 项奖励
RyomaFujiki
初学者
23,579 次查看
Hello Victor G,
Your advice has partially solved the problem. Thank you very much.
But we have a new problem.
We had already looked at the GoDaddy guide you deployed.
However, we were using the .pfx file we got in step "4. Prepare the Certificate" and uploaded it to the EMA WebUI.
By using the .pfx file exported from the Cert store, we were able to add four lines of certificates and ACM provisioning with EMA 1.7.1.
However, for some reason we are not able to provision only one PC that supports OCR.
The AMT on that PC is v16.0.15.
It is on the same network as the other provisioned PCs and I installed EMAAgent using the same procedure.
That PC was provisioned with EMA 1.6.1 and a single line certificate with no problems.
I have attached a Log that may be helpful.
I would like to check the OCR so we can resolve this issue.
Any advice would be appreciated.
Ryoma Fujiki
0 项奖励
回复
