Intel vPro® Platform
3056 Diskussionen
Intel EMA Certificate Chaining Issue
RyomaFujiki
Einsteiger
40.486Aufrufe
Hello.
I am in the process of setting up EMA in Admin Control Mode, but I am unable to provision AMT with TLS-PKI.
I can see the following error in the Platform Manager
Error Message: Unable to get activation certificate chain from the database.
I have tried the following article on this, but it did not resolve the issue.
https://www.intel.co.jp/content/www/jp/ja/support/articles/000090529/software/manageability-products.html
I can connect to CIRA without any problem.
The version of EMA is 1.7.1.
I am using GoDaddy's certificate.
If you know of any solutions, please let me know.
48 Antworten
MIGUEL_C_Intel
12.309Aufrufe
Hello RyomaFujiki,
We are glad Intel® EMA 1.7.1. is working on some endpoints. Do you mind clarifying if the working machines are running Intel® AMT v12?
Regarding the endpoint with issues, please take a picture from the EMA WebUI, showing the provisioning status of it, plus a log from the endpoint.
Located at: EMA log from the endpoint:
[System drive]\Program Files\Intel\EMA Agent\EMAagentlog
We look forward to hearing from you.
Miguel C.
RyomaFujiki
Einsteiger
12.304Aufrufe
Hello Miguel C,
Thanks for the reply.
To answer your question.
We have prepared an image showing that we are provisioned in AMT v12.
Please check the file "AMT_v12_Provisioned.png".
We have prepared  images of the provisioning status of the endpoint with issues.
Please check the files "Provisioning_Status_01" and "Provisioning_Status_02".
No logs were output for the endpoint.
That is all.
Best regards.
MIGUEL_C_Intel
12.297Aufrufe
Hello RyomaFujiki,
Thank you for providing us with the pictures of the working and non-working machines.
Do you mind performing the troubleshooting below and sharing the log or a picture with the error messages?
a) From the EMA WebUI, select the unprovisioned machine, go to actions and select “Stop managing”.
b) Then, go to the endpoint (AMT v16) and unprovision it, we suggest using ACUconfig tool
1) Open a command line as Administrator
       2) Go to the path c: \Program Files (x86) \Intel \SCS ACUConfig
       3) Run:  acuconfig /verbose /output console unconfigure /adminpassword password /full
Note:
https://downloadcenter.intel.com/download/30340/Intel-Configurator
Download and unzip the Intel® Configurator v12.2n into the endpoint
Open the unzipped folder, open the Configurator folder and run ACUConfigInstaller.msi
d) Open the Platform Manager at the EMA WebUI and gather a log of the new installation or a picture. The complete provision can take almost 4 to 5 minutes.
Miguel C.
RyomaFujiki
Einsteiger
12.290Aufrufe
Hello Miguel C,
Thank you for your response.
I followed the procedure and collected logs and images.
Provisioning is not done.
Please check.
Regarding the timestamps in the logs, the endpoints and EMA Server are off by 4 hours due to regional settings.
Ryoma Fujiki
MIGUEL_C_Intel
12.286Aufrufe
Hello, RyomaFujiki,
Thank you for your quick response.
I reviewed the logs and screenshot and noted the endpoint was not unprovisioned. I am resending the steps and clarifying some of them.
    3) Run: acuconfig /verbose /output console unconfigure /adminpassword <password> /full
Note:
<password>  Type the password created on the EMA configuration.
c) Restart the endpoint and install the EMAagent file.
Miguel C.
RyomaFujiki
Einsteiger
12.269Aufrufe
Hello Miguel C,
I followed the procedure again and prepared images and logs.
Please confirm.
I checked the EMA 1.8.0 release, updated and confirmed, but the problem was not resolved.
I prepared another Alder Lake machine (non-OCR supported) and checked it, but the same problem occurred.
Is it possible that the problem is caused by Intel AMT Version?
Ryoma Fujiki
MIGUEL_C_Intel
12.255Aufrufe
Hello, RyomaFujiki,
Thank you for your quick response with the outcome using Intel® EMA 1.7.1 and 1.8.0.
I reviewed the limitation; and found the following: On the TLS-relay option, the option to resolve hostnames via Domain Name System is unavailable (DHCP option 15). In the case of the newer machines AMT v16, it is necessary to manually install the PKI DNS suffix in the endpoints.
  1. Do you mind confirming if the endpoints with AMT v16 have a wired connection without a docking station?
  2. Is it possible to perform a test using the latest version of Intel® Endpoint Management Assistant (Intel® EMA) v1.8.0 with the Client Control Mode option? Please remember to stop managing the endpoints from the actions option in the EMA WebUI.
Look forward to your response; if there is no response to this email, we will send you a follow-up on 8/1/2022.
RyomaFujiki
Einsteiger
12.244Aufrufe
Hello Miguel C,
Thank you for the information that this is a limitation in AMT v16.
We can test with a wired connection and the CCM option, but we want to check the OCR functionality and need to provision with ACM.
Therefore, we want to install DNS suffix manually.
From my research, I believe we are to use USBFileTool, but I am not sure what command to enter.
I would appreciate it if you could give me specific instructions.
That is all.
Best regards
MIGUEL_C_Intel
12.231Aufrufe
Hello, RyomaFujiki,
We will gladly assist you with the configuration.
Please let us know if you are referring to USB redirection when you talk about the USB file tool. Details about USB redirection are available in section 1.2.8
https://www.intel.com/content/dam/support/us/en/documents/software/manageability-products/intel-ema-admin-and-usage-guide.pdf#page=13
The command examples are in the document below.
Intel® Endpoint Management Assistant (Intel® EMA) API Sample Scripts
https://www.intel.com/content/www/us/en/download/19693/30076/intel-endpoint-management-assistant-intel-ema-api-sample-scripts.html
Look forward to your response; if there is no response to this email, we will send you a follow-up on 8/2/2022.
RyomaFujiki
Einsteiger
12.194Aufrufe
Hello Miguel C,
I was not referring to USB Redirection, but to USBFile.exe in the AMT SDK.
How specifically can I manually change the DNS suffix to allow ACM provisioning with AMT v16, either with USBFile.exe or USB Redirection?
I saw an example of the USB Redirection command, but was not sure how to change the DNS suffix.
Ryoma Fujiki
JoseH_Intel
12.125Aufrufe
Hello RyomaFujiki,
We are looking into this. Please allow us some time for research.
Jose A.
MIGUEL_C_Intel
11.997Aufrufe
Hello RyomaFujiki,
The USB tool available at the SDK is necessary when you are using a Self-Certificate, and the hash of it is not included in the BIOS firmware of the AMT machines.
In your case, the hash of GoDaddy’s Certificate is already in the BIOS firmware; you just need to access the MEBx BIOS (Ctrl+p) and type the PKI DNS suffix if you are using static IP addresses. If you are using DHCP, option 15 in ISS is active in the EMA server; the EMA agent file will configure the PKI DNS suffix in the endpoints.
If a web meeting is necessary, what is the earliest hour to meet with us from Monday to Friday?
Look forward to your response; if there is no response to this email, we will send you a follow-up on 8/8/2022.
RyomaFujiki
Einsteiger
11.988Aufrufe
Hello Miguel C,
Thanks for the info about the USB tool.
We have found that we do not need it.
I read your response and am I correct in understanding that due to limitations, we cannot provision with ACM on AMT v1.6 PCs unless we are using a static IP address?
I tried provisioning manually with the PKI DNS suffix, but provisioning failed on an AMT v1.6 PC.
The error seems to be the same as before.
The procedure is as follows. Please point out if I am wrong.
Create an AMT profile with the following settings
General :Use TLS Relay
Management Interfaces :Check all items
IP Address :Use a static IP address from host
Create an endpoint group, apply the profile you created, and configure TLS-PKI settings.
Set a static IP address for the endpoint.
4. Unprovision the endpoint PC.
5. Access MEBx and enter "ematest.f5.si" for the PKI DNS suffix
6. Install EMA Agent on the endpoint PC
7. Verify that it is provisioned
The above steps allowed me to provision ACM on my AMT v12 PC, but not on my AMT v16 PC.
Ryoma Fujiki
MIGUEL_C_Intel
11.978Aufrufe
Hello RyomaFujiki,
I am glad you were able to add the PKI DNS suffix to the endpoints without the USB tool.
It is possible to provision the endpoints in Admin Control Mode, EMA software v1.8.0 using DHCP or static IP addresses. Both options work with CIRA and TLS-relay communication.
RyomaFujiki; we would like to set a Web meeting with you, using Microsoft Teams. Please let us know the earliest hour from Monday to Friday to set the meeting. We are interested in your case and resolving the issue while using endpoints with AMT version 16.
The EMA configuration looks good.
Look forward to your response; if there is no response to this email, we will send you a follow-up on 8/9/2022.
RyomaFujiki
Einsteiger
11.913Aufrufe
Hello Miguel C,
We would like to schedule a web conference in Teams on Friday, 8/12 at 10:00 JST.
Ryoma Fujiki
MIGUEL_C_Intel
11.908Aufrufe
Hello, Ryoma Fujiki,
By any chance, is it possible to reschedule the web meeting for 8:00 AM JST on Friday, 8/12?
I look forward to hearing from you.
RyomaFujiki
Einsteiger
11.886Aufrufe
Hello Miguel C,
Regarding the web conference, we are okay to schedule for Friday 8/12 at 8:00 AM JST.
Materials will be shared for a smooth meeting.
Ryoma Fujiki
MIGUEL_C_Intel
11.868Aufrufe
We have sent you a private email; in order to collect sensitive details about your setup and issue.  Please reply to the private email.
I look forward to your feedback.
RyomaFujiki
Einsteiger
11.844Aufrufe
Hello Miguel C,
I was unable to respond yesterday due to a national holiday.
The person who has access to the account email will be on vacation until 8/19 and will respond to your email after 8/22.
We'll decide on the meeting dates at that time as well.
Ryoma Fujiki
MIGUEL_C_Intel
11.811Aufrufe
We understand; there is no rush.  We will wait for your update after 8/22.
RyomaFujiki
Einsteiger
11.709Aufrufe
Hello Miguel C,
Regarding the web conference, we are okay to schedule for Friday 8/26 at 9:00 AM JST.
It is difficult to schedule a meeting starting at 8:00 AM.
I would also like to know if there is any information I should prepare for the conference to make it run smoothly.
Ryoma Fujiki
Antworten
