Intel vPro® Platform
3054 Discussions
Intel EMA server scaling
Norbert_
We are about to implement Intel EMA and would like some help in sizing the server. We have a network of nearly 5000 endpoints and it is growing. Can you tell me the recommended server configurations?
Also, can the SQL server be running on a server where SQL for other applications is also running? Or is it advisable to have a separate server for both the application and the SQL?
Thank you in advance!
Norbert
Victor_G_Intel
Hello Norbert_,
In regard to your request, please bear in mind that we only provide troubleshooting support for already created deployments; however, in the resources below you will find all the information you need to start implementing EMA. If you face any issues along the way, feel free to reach out.
Intel® Endpoint Management Assistant (Intel® EMA) Single Server Installation and Maintenance Guide (https://www.intel.com/content/www/us/en/support/articles/000055629/software/manageability-products.html)
Intel® Endpoint Management Assistant (Intel® EMA) Admin and Usage Guide (https://www.intel.com/content/www/us/en/support/articles/000055619/software/manageability-products.html)
Intel® Endpoint Management Assistant (Intel® EMA) Quick Start Guide (https://www.intel.com/content/www/us/en/support/articles/000055627/software/manageability-products.html)
Intel® Endpoint Management Assistant (Intel® EMA) Video Series (https://www.intel.com/content/www/us/en/support/articles/000056028/software/manageability-products.html)
In section 1.3 Installation Prerequisites of our Intel® Endpoint Management Assistant (Intel® EMA) Single Server Installation and Maintenance Guide, you will find all you need to set up the EMA server.
Additionally, in section 1.3.3 Database of the same guide, you will find all details related to the Microsoft SQL server.
In case you have any questions don’t hesitate to let us know.
Victor G.
Victor_G_Intel
Hello Norbert_,
Victor G.
Victor_G_Intel
Hello Norbert_,
We are glad to know that you have found the information provided helpful. Since the thread is now solved, we will proceed to close it.
Victor G.
