Intel vPro® Platform
2780 Discussions
Locally unprovision a vPro device through software
How can I unprovision a device locally through the HECI driver? Is there a utility that allows me to do this? I've tried resetting the CMOS on a HP dc7900 multiple times, by pulling the battery, and using the CMOS reset button. This hasn't reset the MEBx password for some odd reason. I did log into the MEBx and performed a full unprovision, and there is no provisioning record available, but the ConfigMgr client oobmgmt.log still reports that the device is already provisioned.
Trevor Sullivan
Systems Engineer
OfficeMax Corporation
Howdy,
To reset the BIOS, what I do is unplug the machine and hit the power button. With it still
unplugged, remove the battery from the mobo, and look for a CMOS Reset button. I've never
touched a 7900, but I have a 7800 and there is a yellow button. Press and hold the button
down and count to 5 slowly (1 Mississippi 2... works good) and once you reboot I've found
that it resets the ME just fine.
Even though you reset the ME firmware, it doesn't remove the record from SCCM. I'm not
exactly sure how to go about that, but I am sure it's because of the record still in the database.
Thanks for the response Johnny.
PEBKAC. Move along, nothing to see here.
It kept re-provisioning against one of my other site servers, because before my holiday vacation, I had manually assigned it to another site code for testing.
I'd still be interested in knowing if it's possible to reset the MEBx through software though. It would be very handy.
Trevor Sullivan
Systems Engineer
