Intel vPro® Platform
3052 Discussions
Manageability Developer Tool Kit error in Win7 x64
OS : WIN7 X64
When connect to a managed client show application exception error. Below is log files but I have test in XP OS it's ok.
2011/9/8 15:12:02
Version: 7.0.11161.2
ERROR: System.TypeLoadException: 未能从程序集"CIMFramework, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null"中加载类型"Intel.Manageability.Cim.Typed.IPS_OptInService"。
在 ManageabilityStack.AmtUserConsent.fetchCache()
在 ManageabilityStack.AmtSystem.ConnectEx(Object parameter)
在 System.Threading.ThreadHelper.ThreadStart_Context(Object state)
在 System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
在 System.Threading.ThreadHelper.ThreadStart(Object obj)
RECENT EVENTS
-> [15:12:02] Event: Service Setup: http://192.168.1.100:16992/EventManagerService http://192.168.1.100:16992/EventManagerService
-> [15:12:02] Event: NetworkCredential HTTP Digest: admin, Acmec0rp!
-> [15:12:02] Event: Service Setup: http://192.168.1.100:16992/RemoteControlService http://192.168.1.100:16992/RemoteControlService
-> [15:12:02] Event: Service Setup: http://192.168.1.100:16992/NetworkTimeService http://192.168.1.100:16992/NetworkTimeService
-> [15:12:02] Event: Service Setup: http://192.168.1.100:16992/RedirectionService http://192.168.1.100:16992/RedirectionService
-> [15:12:01] Event: Service Setup: http://192.168.1.100:16992/HardwareAssetService http://192.168.1.100:16992/HardwareAssetService
-> [15:12:01] Event: NetworkCredential HTTP Digest: admin, Acmec0rp!
--- END LOG ENTRY ---
Is this in reference to the Outpost tool? If so, this is a known issue and Intel is currently working on a fix. No ETA has been given, but at least we know it will be fixed.
I posted a similar response to another user who is having the similar issue you are. You can view that post here: /thread/24566 http://communities.intel.com/thread/24566
Thanks!
LM
Hi LM,
Thanks your reply. I think you are right. I've read your post as below.
Thanks!
Rain
