Intel vPro® Platform
3072 Discussions
Method for PKI provisioning without DHCP option 15 set?
Mike_Modality
I have some system in remote offices that I'd like to remotely enroll into EMA, in most cases I can likely set DHCP option 15 to the suffix I need, from an automation standpoint however it would be convenient if I could get it to pickup the connection suffix entered on the host system to be able to deploy it to multiple locations without having to update the router in each location.
We have remote tools on our devices already and can run powershell scripts and installers like the EMA agent already automatically.
I'm thinking it's setup this way from a security perspective to prevent malicious activity that you require it to be done from the dns server, but there's tricks to that as well like a small local dns application if you were being dirty, so I'm not sure if that's the sole reason or if there is something I can add to the host OS to allow it to provison. It would also be convenient as something we included in our deployment scripts to make life easier for systems with vpro.
Victor_G_Intel
Hello Mike_Modality,
Thank you so much for contacting Intel customer support,
To be able to check any possibilities on our end to help you with this please provide the information below:
  1. What EMA version you are currently using?
  2. How many endpoints do you have in your deployment?
  3. What AMT version(s) are currently being used on your endpoints?
  4. Is your installation a single server or a multi-server one?
  5. What OS is being run in the EMA server(s)?
  6. Do you use Client control mode or Admin control mode in your endpoints?
Victor G.
Intel Technical Support Technician
Victor_G_Intel
Please let me know if you need further assistance.
Victor G.
Victor_G_Intel
We have not heard back from you.
Victor G.
