I've set up Intel AMT SCS and now I'm trying to connect one machine to it, but when I run the Activator utility I'm getting such an output:
>activator /s https://server.somedomain.net/amtscs_rcfg /o OU=IntelAMT,DC=somedomain,DC=net /p 7 /c /h
Step Into: CheckAMT
Connected to HECI driver, version: 3.0.30.1086
BIOS Version: 786F1 v01.04
Intel AMT code versions:
Flash: 3.0.1
Netstack: 3.0.1
AMTApps: 3.0.1
AMT: 3.0.1
Sku: 14
VendorID: 8086
Build Number: 1104
Recovery Version: 3.0.1
Recovery Build Num: 1104
Legacy Mode: False
Setup and Configuration:
In process
Setup and Configuration TLS Mode:
PSK
Step Into: CheckPKIPPSPIDStatus
Step out: CheckPKIPPSPIDStatus error 0
Step Into: CSCSER::PerformSCSRemoteConfiguration
Step Into: CSCSER::SCSSetAMTIdentity
AMT version: 3.0 Step Into: StartConfiguration
Flash: 3.0.1
Netstack: 3.0.1
AMTApps: 3.0.1
AMT: 3.0.1
Sku: 14
VendorID: 8086
Build Number: 1104
Legacy Mode: False
In process
Intel AMT Mode:
Non Legacy
Remote Configuration:
enabled
PSK
PT_STATUS_INVALID_PT_MODE: Command is not permitted in current operating mode.
Activate Intel AMT configuration:
failure
PT_STATUS_INVALID_PT_MODE: Command is not permitted in current operating mode.Step Into: StartConfiguration
Step out: StartConfiguration error 3
After StartConfiguration 3
Retrieved PID from the machine. Pid is 35HM3WFT
Connect to gandalf.delfopl.magnetto.net: at port: 9971:Sent hello message successfully!
Exit with code 0
All operations succeeded; interface opened.
and at SCS console the station connects to right profile (id 7) but is in "not configured" status.
Any suggestions?
PS. Sorry for my English, I'm still learning
