Intel vPro® Platform
2835 Discussions
Problems while, PXE Booting on INTEL AMT provisioned machines
zkhan5
Hi guys,
We have configured an environment with Intel SCS and intel vpro enabled clients. We have successfully created policies and have distributed these to our clients. All of the funtions/settings are working as expected, we are using the following policy
Profile Name: KerberosProfile
Profile Type: Intel AMT
Network Settings
FQDN will be the same as the Primary DNS FQDN
IP will be taken from DHCP
Active Directory Integration
Active Directory OU:OU=AMT Objects,DC=Demo,DC=local
Access Control List (ACL)
User 1: administrator
User Type: Digest
User has both remote and local access to the realms listed below
Realms: Redirection, PT Administration, Hardware Asset, Remote Control, Storage, Event Manager, Storage Administration, Agent Presence Local, Agent Presence Remote, Circuit Breaker, Network Time, General Info, Firmware Update, EIT, Local User Notification, Endpoint Access Control, Endpoint Access Control Administrator, Event Log Reader, User Access Control
User 2: Demo.LOCAL\AMT-Admins
User Type: Active Directory
User 3: adminkvm
User Type: Digest
User 4: Demo.LOCAL\Domain Users
User has local access to the realms listed below
Transport Layer Security (TLS)
Server authentication used for remote interface
Server Authentication Certificate Properties:
Anonymous
Not applicable
Please note the Intel® vPro™ Expert Center discussion forums are not officially monitored by Intel.
To directly engage with experts to log and track support issues related to Intel® vPro™ Technology platforms please contact the Intel® Business Support portal: https://bizsupport.intel.com/ https://bizsupport.intel.com/
Bruno_Domignues
Sean,
I have an equivalent environment in my lab and it's working, both on 802.1x and "unprotected" network. Can you tell me about your AMT versions, brands/model?
Best Regards!
-Bruno Domingues
zkhan5
Hei Bruno,
We have tried on the following clients
1) Dell Latitude E7440
AMT version 9.5.14
AMT SKU Intel(R) Full AMT Managebility
SystemDataversion 9.0.0
BIOS revision A09
2) Dell Latitude E7440
AMT version 9.5.14.14.1724
Mbex v 9.0.0.0025
BIOS revision A09
3) Dell 9010
AMT version 9.0.31
4) HP Elitedesk
I shall provide the details, we have tried updating to newest version of BIOS and Mbex
Sean
zkhan5
Hi Sean,
I found that I have similar problem like you. Do you have any update of this issue?
Jan
Hi Sean,
I started using workaround - instead of booting using PXE I'm using IDER for Windows PE loading. If you want to load image quicker, you can load small Linux image which can load bigger Win PE image. So, when you are using iAMT and 802.1x together, be sure that PXE boot is dead for good.
Jan
OOlup
Hi Sean,
I'd like to confirm the same problem.
Being knocking my head against the wall for some time now. :-)
Any progress, beside JanCS workaround.
One thing I'd like to add is, that sometimes the BOOT.WIM is loaded and started, but in some unknown moment network interface loses connection with dhcp and image loading stops and error's out.
Oliwer
