Intel vPro® Platform
3065 토론
Required: Tool to deactivate AMT - code to do same.
직원
4,017 조회수
I have a requirement to deactive the AMT setting on 2500 + workstations.
The problem is that the sol devive is conflicting with a 3rd party peripheral.
What I would like to know is if there is a way to set the manageability mode fromAMT back to none - in effetc reversion the process carried out by the activator utility.
I have not had any sucess finding a suitbale utility - I was hoping that the code used in the activator utiluity could be modified to chnage the end state to None.
Alternatively is there a way to force the SOL devive to use a specific port number.
I would really appreciate your assistance with this.
0 포인트
5 응답
Salem_W_Intel1
1,757 조회수
Hi, there!
Regretfully, there is no shuch tool/utility by means of which AMT can be disabled. I do appreciate your feedback and will make sure your comment reaches the proper department for future consideration. As for now, to disable AMT, please, follow these manual steps:
1. Boot the system to the BIOS
2. Go to the 'Intel ME' Tab
3. Enter Intel(R) Management Engine Password and type a new password. The password must be at least 8 digits, numbers, upper case and lower case letters and an special character.
4. There will be a pop-up message where it indicates the password is successfully changed; you just need to press 'enter'
5. Enter the Intel(R) Management Engine Configuration
6. On Manageability Feature, there are 3 options [None, Intel(R) AMT, ASF], and select 'None'.
7. Save the changes and exit BIOS.
0 포인트
직원
1,757 조회수
Hi ChrisNZ,
Let's gather a bit more info to see what options we have:
what version of AMT are you working with?
Have these systems been provisioned?
0 포인트
직원
1,757 조회수
Josh,
no they have not been fully provisioned. the versions are 3.0.1 and 5.0.3.
0 포인트
직원
1,757 조회수
Thanks Chris, we are currently looking into this and I will keep you up to date as I get more info.
Josh
0 포인트
직원
1,757 조회수
Hi Chris,
For your 3.x clients, try the COMPORT.EXE tool attached to this thread: /message/8057# 8057 http://communities.intel.com/message/8057# 8057 (example: c:\COMPORT.EXE COM4)
For the 5.x clients, try this switch when installing or reinstalling the driver: setup.exe -port
here are the available switches when installing LMSSOL:
These 2 options should allow for you to move the SOL comport to one that you specify.
hope this helps!
Josh
0 포인트
응답
