Intel vPro® Platform
2995 Discussions
Running OOBMC outside of SCCM
A while back I received a .vbs script and docs from Intel on running the AMT OOB Management console outside of SCCM.
The script didn't work and didn't satisfy my need.
The problem I have is my normal login account is too large to work on all of our AMT devices. It's a Kerberos token size issue.
The solution is to logoff and login with a test account that has a small Kerberos token size. This introduces other problems with accessing network shares without logging off and back on again. So I set out to create a script using cmd line, see below.
This script will get the additional data via a WMI query to the SCCM server and then run the runas command on the oobconsole.exe.
You will need the SCCM console installed. Change the 2 variables at the top of the script and you are good to go.
This should work on XP, Vista and 7.
No warranties expressed or implied. Use at your own risk, yada, yada, yada.
________________________________________________________________
@echo off
:ClearVariables
set _Version=1.0
set _pcname=
set _SID=
set _newloginas=
:: Change these Variables for your environment
set _loginas=DOMAIN\USER
Set _SCCMServer=FQDN of SCCM Server</p...
