Intel vPro® Platform
2956 Discussions
SCS Add-on for SCCM install won't let me choose SCCM2012
SWhit11
I'm trying to install the scs add-on for sccm. When I'm going through the setup wizard, on the SCCM Settings screen the wizard detects my installation folder and site code correctly, but not the sccm version. The radio button for 2007 is marked, and the radio button for 2012 is greyed out. I am running SCCM 2012 SP1. What do I need to do to get this working?
Alan_A_Intel
aurock,
Can you tell me what version of the SCS Add-on you are running? Also, would it be possible to upload the log file that was created during the installation attempt? The log is located in the same folder as the SCCMAddon.exe, and is called SCCMAddon.log.
-Alan
SWhit11
Thanks for the reply.
v1.0.0.36
SCCMAddon.log only shows the following:
2013-07-11 10:36:08,790 - DEBUG: Starting
2013-07-11 10:36:08,806 - INFO : Starting Log
2013-07-11 10:36:09,853 - DEBUG: Entering SettingsViewModel.ctor
2013-07-11 10:36:10,978 - INFO : Detected x64 bit installation folder: C:\Program Files\Microsoft Configuration Manager
I'm not sure that there's much of use there. I never continued beyond the Settings screen, since it wouldn't let me choose SCCM 2012 and I wasn't sure it was safe to go forward with the setup.
Alan_A_Intel
We are currently working on a fix for this issue. I will update you as soon as it's available.
GPole1
You got further than I did with SCCM 2012 SP1
2013-07-12 12:43:01,837 - DEBUG: Starting
2013-07-12 12:43:01,845 - INFO : Starting Log
2013-07-12 12:43:01,980 - DEBUG: Entering SettingsViewModel.ctor
2013-07-12 12:43:02,098 - ERROR: Could not identify SCCM installation
SCCMConfig.Domain.SCCMProbingException: Cannot detect SCCM Installation folder. Attempted: C:\SMS
at SCCMConfig.DAL.SCCMProber.Detect()
at SCCMConfig.Actions.ActionPerformer.Detect()
at Intel.SCS.ACIWizard.ViewModel.WelcomeViewModel.b__1()
GPole1
Since the SCS Add-on does not work, can you please provide the configuration_IntelSCS8_iAMT.mof file that we need to manually configure SCS with SCCM as instructed in this blog.
http://blogs.bamits.com.au/2012/09/integrating-sccm-2012-with-scs-81.html?showComment=1373904086573# c7871508478861659032 Blair Muller's Blog: Integrating SCCM 2012 with SCS 8.1
Also, how is the sms_def.mof edited?
Greg Polen
Texas A&M University
Alan_A_Intel
Greg,
We should have a new version of the SCS Add-on available by next week.
-Alan
Any word on when the new version will be available?
Alan_A_Intel
Unfortunately, there has been a slight delay with the release of the new SCS Add-on. As of now there isn't a firm date for release.
There is another option if you're not able to wait for the new Add-on. You can manually integrate SCS using the instructions located here.
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21696 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21696
Alan,
Could you give us an estimate on how long until the patch is released?
Alan_A_Intel
GPole1
The new version 1.0.0.71 still gives me the same error when installing.
2013-10-23 12:52:37,456 - DEBUG: Starting
2013-10-23 12:52:37,472 - INFO : Starting Log
2013-10-23 12:52:37,597 - DEBUG: Entering SettingsViewModel.ctor
2013-10-23 12:52:37,690 - FATAL: Could not identify SCCM installation
Any Ideas????
-Greg
SWhit11
The new version installed without any further issues, but now that I've got the discover task sequence enabled and deployed, it's failing on all clients. Looking in the smsts.log, I see several error messages with an 0x80004005 code at the end, which I believe means access denied.
Does anyone know of something simple I might have overlooked which would cause this issue?
Alan_A_Intel
Check that the task sequence user is a local admin.
SWhit11
I believe the task sequence executes under the SCCM server's computer account, which does have local admin rights on our systems. I also added the new AMT Admin account that I created and used when setting up the profile in SCS, just in case.
I did make a little progress last night... I edited the "Intel AMT Discover and Report" task sequence, removing the quotation marks from the command line. That got the batch file to run, but I'm hitting an error towards the end. It looks like the task sequence is working now, but ACUConfig is running into issues. It's tough to grab the "Remote_SystemDiscovery.log" file since it's deleted as soon as the task sequence finishes, but I got a copy pretty close to the end:
2013-08-15 09:17:35: Thread:6004(INFO) : ACU Configurator , Category: HandleOutPut Source: Src\ActivatorUtils.cpp : HandleOutput Line: 210: Starting log 2013-08-15 09:17:35
2013-08-15 09:17:35: Thread:6004(DETAIL) : ACU Configurator, Category: VerifyFileSignature Source: Src\ActivatorMain.cpp : wmain Line: 122: Verifying the digital signature of ACU.dll, this operation might take up to 3 minutes...
2013-08-15 09:17:35: Thread:6004(INFO) : ACU Configurator , Category: VerifyFileSignature Source: Src\ActivatorUtilsWin.cpp : VerifyFileSignature Line: 457: The file "C:\_SMSTaskSequence\Packages\XYZ0006D\ACU.dll" is signed and the signature was verified.
2013-08-15 09:17:35: Thread:6004(DETAIL) : ACU.dll, Category: SetCompatibilityMode Source: Src\ActivatorDll.cpp : SetCompatibilityMode Line: 104: Set compatibility mode to 8.0.
2013-08-15 09:17:35: Thread:6004(INFO) : ACU Configurator, Category: -SystemDiscovery- Source: Src\ActivatorMain.cpp : wmain Line: 311: computer.domain.com: Discovering the System information...
2013-08-15 09:17:35: Thread:6004(DETAIL) : ACU Configurator , Category: -Start- Source: Src\ActivatorDllWin.cpp : SystemDiscovery Line: 51: ***** Start SystemDiscovery ******
2013-08-15 09:17:35: Thread:6004(DETAIL) : ACU Configurator , Category: -Start- Source: Src\HECIDiscovery.cpp : HeciDiscovery Line: 467: ***** Start HeciDiscovery ******
2013-08-15 09:17:35: Thread:6004(DETAIL) : ACU Configurator , Category: -Start- Source: Src\HECIDiscovery.cpp : CheckAMT Line: 78: ***** Start CheckAMT ******
2013-08-15 09:17:35: Thread:6004(DETAIL) : ACU Configurator , Category: -HECI- Source: Src\HECIWin.cpp : HECIWin::Init Line: 185: Connected to the Intel(R) Management Engine Interface driver, version 7.1.70.1198
2013-08-15 09:17:35: Thread:6004(DETAIL) : ACU Configurator , Category: -Start- Source: Src\HECIDiscovery.cpp : FWUpdateData Line: 40: ***** Start FWUpdateData ******
2013-08-15 09:17:35: Thread:6004(DETAIL) : ACU Configurator , Category: -END- Source: Src\HECIDiscovery.cpp : FWUpdateData Line: 61: ***** END FWUpdateData ******
2013-08-15 09:17:35: Thread:6004(INFO) : ACU Configurator , Category: AMT Mode Source: Src\HECIDiscovery.cpp : CheckAMT Line: 382: Intel(R) AMT in PROVISIONING_MODE_ENTERPRISE
2013-08-15 09:17:35: Thread:6004(DETAIL) : ACU Configurator , Category: -END- Source: Src\HECIDiscovery.cpp : CheckAMT Line: 461: ***** END CheckAMT ******
2013-08-15 09:17:40: Thread:6004(DETAIL) : ACU Configurator , Category: -Start- Source: Src\HECIDiscovery.cpp : PKIDiscovery Line: 790: ***** Start PKIDiscovery ******
2013-08-15 09:17:40: Thread:6004(DETAIL) : ACU Configurator , Category: Hash Handle Source: Src\HECIDiscovery.cpp : GetPKIHashes Line: 873: Hash Handles number:15
2013-08-15 09:17:40: Thread:6004(DETAIL) : ACU Configurator , Category: -END- Source: Src\HECIDiscovery.cpp : PKIDiscovery Line: 837: ***** END PKIDiscovery ******
2013-08-15 09:17:40: Thread:6004(DETAIL) : ACU Configurator , Category: -Start- Source: Src\HECIDiscovery.cpp : GetAmtFQDN Line: 1256: ***** Start GetAmtFQDN ******
2013-08-15 09:17:40: Thread:6004(DETAIL) : ACU Configurator , Category: -END- Source: Src\HECIDiscovery.cpp : GetAmtFQDN Line: 1333: ***** END GetAmtFQDN ******
2013-08-15 09:17:40: Thread:6004(DETAIL) : ACU Configurator , Category: -Start- Source: Src\HECIDiscovery.cpp : ConfServerDiscovery Line: 1021: ***** Start ConfServerDiscovery ******
2013-08-15 09:17:40: Thread:6004(DETAIL) : ACU Configurator , Category: Status message Source: Src\HECIDiscovery.cpp : ConfServerDiscovery Line: 1082: Error message not found- 0x80008cd9. (0x80008cd9)
2013-08-15 09:17:40: Thread:6004(DETAIL) : ACU Configurator , Category: -END- Source: Src\HECIDiscovery.cpp : ConfServerDiscovery Line: 1095: ***** END ConfServerDiscovery ******
2013-08-15 09:17:40: Thread:6004(DETAIL) : ACU Configurator , Category: GetPID Source: Src\HECIDiscovery.cpp : HeciDiscovery Line: 715: AMT Status code - Invalid AMT mode. (0xc000426b) (GetPID)
2013-08-15 09:17:40: Thread:6004(DETAIL) : ACU Configurator , Category: -Start- Source: Src\HECIDiscovery.cpp : ReInitPTHI Line: 1449: ***** Start ReInitPTHI ******
2013-08-15 09:17:45: Thread:6004(DETAIL) : ACU Configurator , Category: -HECI- Source: Src\HECIWin.cpp : HECIWin::Init Line: 185: Connected to the Intel(R) Management Engine Interface driver, version 7.1.70.1198
2013-08-15 09:17:45: Thread:6004(DETAIL) : ACU Configurator , Category: -Start- Source: Src\HECIDiscovery.cpp : LMSDiscovery Line: 1102: ***** Start LMSDiscovery ******
2013-08-15 09:17:45: Thread:6004(INFO) : ACU Configurator , Category: Discovery Source: Src\HostBasedSetup.cpp : HostBasedSetup::Discovery Line: 410: Calling function Discovery...
2013-08-15 09:17:45: Thread:6004(INFO) : ACU Configurator , Category: Local System Account Source: Src\HostBasedSetup.cpp : HostBasedSetup::GetLocalSystemAccount Line: 199: Calling function GetLocalSystemAccount over MEI...
2013-08-15 09:17:45: Thread:6004(INFO) : ACU Configurator , Category: Local System Account Source: Src\HostBasedSetup.cpp : HostBasedSetup::GetLocalSystemAccount Line: 233: Function GetLocalSystemAccount over MEI ended successfully
2013-08-15 09:17:46: Thread:6004(INFO) : ACU Configurator , Category: Discovery Source: Src\HostBasedSetup.cpp : HostBasedSetup::Discovery Line: 454: Host Based Setup is supported
2013-08-15 09:17:46: Thread:6004(INFO) : ACU Configurator , Category: Discovery Source: Src\HostBasedSetup.cpp : HostBasedSetup::Discovery Line: 484: Current Control Mode: 0 (Not provisioned)
2013-08-15 09:17:46: Thread:6004(INFO) : ACU Configurator , Category: Discovery Source: Src\HostBasedSetup.cpp : HostBasedSetup::Discovery Line: 523: Allowed Control Modes: 2 (Admin) and 1 (Client)
2013-08-15 09:17:46: Thread:6004(INFO) : ACU Configurator , Category: Discovery Source: Src\HostBasedSetup.cpp : HostBasedSetup::Discovery Line: 527: Function Discovery ended successfully
2013-08-15 09:17:46: Thread:6004(DETAIL) : ACU Configurator , Category: -END- Source: Src\HECIDiscovery.cpp : LMSDiscovery Line: 1175: ***** END LMSDiscovery ******
2013-08-15 09:17:46: Thread:6004(DETAIL) : ACU Configurator , Category: -Start- Source: Src\HECIDiscovery.cpp : SecurityDiscovery Line: 1192: ***** Start SecurityDiscovery ******
2013-08-15 09:17:46: Thread:6004(DETAIL) : ACU Configurator , Category: -END- Source: Src\HECIDiscovery.cpp : SecurityDiscovery Line: ...
Alan_A_Intel
In order to keep all of the log information when running the task sequence you will need to pipe the output to a known location. The easiest way to do this is to edit the task sequence and add something like > c:\logfile.log. This will allow you to capture all of the data from that batch file.
While the conclusion from the other thread is true, that you are not able to use SystemDiscovery to capture data to the RCS database when the system is unconfigured. The data here is not being used by the RCS database, but SCCM. SCCM pulls the SystemDiscovery data that is stored locally in the client's registry.
