Intel vPro® Platform
3059 Discussions
Serial over LAN failed in SCCM SP2
Hello guys,
I'm trying to use SOL from my SCCM's OOB Management console but I get this error:
IMR_SOLOpenTCPSession2 with user = DOMAIN\user fail with result 0xC, description: Session Closed
IMR_SOLOpenTCPSession fail with result: 0x0000000C
Everything is working fine. I can control any thing about power options and boot, only when I try to use SOL I get errors.
Hope somebody has gotten something like this and could help
Tks in advanced,
Alexandre.
Problem solved.
It was the kerberos token's size that was bigger than the limit allowed in AMT version 5.0
Here is a great topic that could help other people to solve this kind of problem:
/community/openportit/vproexpert/blog/2009/03/23/kerberos-ticket-size-can-stop-you-from-connecting-to-vpro-systems-and-using-idersol;jsessionid=D1FD1C4D0CD071D22A0E0941FF7D881C.node5COMS http://communities.intel.com/community/openportit/vproexpert/blog/2009/03/23/kerberos-ticket-size-can-stop-you-from-connecting-to-vpro-systems-and-using-idersol;jsessionid=D1FD1C4D0CD071D22A0E0941FF7D881C.node5COMS
Hope it helps.
Wkr,
Alexandre Perazza
