Intel vPro® Platform
2947 Discussions
TLS Alert (Certificate Unknown) occurs during the Secure Host Based Configuration process.
jic5760
We are implementing AMT provisioning on our own without a solution like EMA.
We encountered a problem while implementing Secure Host-Based Configuration to support CSME 19 or higher.
1. Registered the AMT CA certificate.
> rpc amtinfo
Version : 15.0.47
Build Number : 2521
SKU : 16392
Features : AMT Pro Corporate
Control Mode : pre-provisioning state
DNS Suffix : 192.168.1.10
> rpc amtinfo -cert
---Certificate Hashes---
Our AMT CA (Active)
SHA256: cabc80186952320c73691e6c4d62379a7d9a52ca246e34881b83ad1a51b9ac12
2. StartConfigurationHBased
StartConfigurationHBased was called as follows.
StartConfigurationHBased(
  ServerHashAlgorithm = CERT_HASH_ALGORITHM_SHA256,
  ServerCertHash [SHA_512_KEY_SIZE]byte = SHA 256 HASH of Provisioning Certificate,
  HostVPNEnable = False,
  SuffixListLen = 0,
  NetworkDnsSuffixList [320]byte
3. The Provisioning server is connected to 127.0.0.1:16993.
But TLS Handshake Failure.
- Both the provisioning certificate and the CA certificate have been sent.
- The hashes of the CA certificate and provisioning certificate are the same as those sent in steps 1 and 2.
Provisioning Certificate:
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            01:8d:7c:e8:91:6a:64:14:68:54:96:b8:98:b1
        Signature Algorithm: sha256WithRSAEncryption
        Issuer: CN = Our AMT CA, C = KR
        Validity
            Not Before: Feb  6 05:33:52 2024 GMT
            Not After : Feb  3 05:33:52 2034 GMT
        Subject: CN = 192.168.1.10, OU = Intel(R) Client Setup Certificate
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                Public-Key: (2048 bit)
                Modulus:
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            X509v3 Basic Constraints: critical
                CA:FALSE
            X509v3 Key Usage: critical
                Digital Signature, Non Repudiation, Key Encipherment, Key Agreement
            X509v3 Extended Key Usage: critical
                TLS Web Server Authentication, 2.16.840.1.113741.1.2.3
            X509v3 Subject Alternative Name:
                DNS:192.168.1.10
            X509v3 Subject Key Identifier:
                58:CE:02:47:70:49:8C:C1:7B:DB:9E:FA:DE:C0:3D:8D:76:9A:5C:CA
            X509v3 Authority Key Identifier:
                B7:FE:10:B2:C9:C8:E8:64:92:6E:17:D5:21:B1:40:72:66:A7:CF:89
            Netscape Cert Type:
                SSL Server
    Signature Value: ...
MIGUEL_C_Intel
Hello, jic5760,
I noticed there is a similar post open; the title is What is AMTCertHash in StartConfigurationHBased?
https://community.intel.com/t5/Intel-vPro-Platform/What-is-AMTCertHash-in-StartConfigurationHBased/m-p/1568585#M11167
The developer team is reviewing your request; please be patient. Custom Intel® AMT configurations require further investigation and tests.
Miguel C.
jic5760
Even if ignore the differences in AMTHash, there will be no problem in operation.
It's just that the AMT Device cannot be verified.
Would it be helpful if I could give you a sample program?
MIGUEL_C_Intel
Hello, jic5760,
We appreciate your post regarding the questions about the certificates. Being that this is a support forum for Intel® EMA, AMT, Management Engine, and your question is more for development; the best place to get the appropriate response would be our developer's forum. Please re-post your question for visibility with the appropriate community:
https://community.intel.com/t5/Developer-Software-Forums/ct-p/developer-software-forums
Miguel C.
MIGUEL_C_Intel
Hello, jic5760,
Thank you for your comprehension.  I am closing the forum.
Miguel C.
