We are unable to remote provision a Dell Precision Mobile 5510 via Wi-Fi. We get the following error below (in bold). Note: this model does not have an on board LAN adapter. How can we fix this?
Starting log 2016-10-27 15:22:57
Verifying the digital signature of ACU.dll, this operation might take up to 3 minutes...
Entering
Exiting
Set compatibility mode to 10.0.
ACUConfig 11.0.0.214
MyNotebook.MyDomain.corp: Starting to configure AMT via RCS...
Entering
Connected to the Intel(R) Management Engine Interface driver, version
11.0.0.1181
Entering
Exiting
Intel(R) AMT in PROVISIONING_MODE_ENTERPRISE
Entering
Exiting
Exiting
Entering
Exiting
Calling function Discovery...
Calling function GetLocalSystemAccount over MEI...
11.0.0.1181
Function GetLocalSystemAccount over MEI ended successfully
Host Based Setup is not supported (WS-MAN call Failed with gSoap error code: 24)
Function Discovery ended successfully
Entering
Exiting
GetHostAndMEInfo output data:
IsAMT:True,
isEnterpriseMode:True,
configurationMode:2,
isRemoteConfigEnabled:True,
AMTversion:11.0.0,
isMobile:True,
provisioningTlsMode:2,
uuid:4C4C4544-0032-4A10-8051-B8C04F4D4332,
isClientConfigEnabled:False,
hostBasedSupport:False,
configurationState:2,
FQDN:MyNotebook.MyDomain.corp,
embeddedConfigurationAllowed:False.
isLANLessPlatform:True.
PKIDNSSuffix:MyDomain.corp
***** Start RemoteConfiguration ******
Entering
Exiting
Get OS IP:An invalid IP address was supplied in the parameter.
-IPAddress
Entering
Exiting
Entering
Exiting
RCSaddress=MyRCSServer.MyDomain.corp, RCSWMIUser=, RCSProfileName=LAN-LESS
RCSaddress=MyRCSServer.MyDomain.corp, RCSWMIUser=, UUID=4C4C4544-0032-4A10-8051-B8C04F4D4332, ConfigMode=3, PID=, RCSProfileName=LAN-LESS, AMTVersion=11.0.0, OldADOU=, Configure AMT Name= True. Configure AMT IPv4= True. AMT Name= Host Name- MyNotebook Domain Name- MyDomain.corp . Source For AMT Name= Host Name- MyNotebook Domain Name- MyDomain.corp . Default OS Name= Host Name- MyNotebook Domain Name- MyDomain.corp . Configure AMT IPv4 to DHCP mode= True.
***** END RemoteConfiguration ******
Exit with code 75.
Details: Failed to complete remote configuration of this Intel(R) AMT device.
Initial connection to the Intel(R) AMT device failed.
A TCP error occurred. Make sure that the destination settings are correct and that a network connection exists to the target.
ACUConfig failed with error 75
Starting log 2016-10-27 15:24:02
Entering
Exiting
MyNotebook.MyDomain.corp: Starting to discover the system information...
***** Start SystemDiscovery ******
Entering
Entering
11.0.0.1181
Entering
Exiting
Entering
Exiting
Exiting
11.0.0.1181
Entering
Exiting
Entering
Hash Handles number:19
Exiting
Entering
Exiting
Entering
AMT Status code - Essential data is missing from the AMT.
(0xc0004a71)
Exiting
AMT Status code - An internal error has occurred in the Intel(R) AMT device. This might indicate an interface error, or an application error.
(0xc0004269) (ConfServerDiscovery)
Entering
11.0.0.1181
(0xc0004269) (GetPID)
Entering
11.0.0.1181
Entering
11.0.0.1181
Exiting
Entering
Exiting
Entering
Exiting
Entering
Exiting
Entering
Exiting
Exiting
Entering
Exiting
-IPAddress
Entering
Exiting
Entering
Exiting
11.0.0.1181
Connection data - Connection type: HTTP, FQDN: MyNotebook.MyDomain.corp, IP: 127.0.0.1, UserName: $$OsAdmin
Connection Info-MyNotebook.MyDomain.corp $$OsAdmin HTTP_CONN:
Failed while calling
WS-Management call
GetAmtVersion (CIM_SoftwareIdentity.Get). Intel(R) AMT connection error
0xc000521c: A TCP error occurred. Make sure that the destination settings are correct and that a network connection exists to the target.
Soap call
GetCoreVersion. Intel(R) AMT connection error
WS-Management call
Soap call
Testing the connection with AMT IP instead of FQDN. 127.0.0.1
WS-Management call
Soap call
WS-Management call
GetAmtVersion (CIM_SoftwareIdentity.Get). Intel(R) AMT connection ...
Hmm,
As I answered you in other discussion it is not possible to configure LAN less devices straight from Intel RCS using Remote Configuration method.
Intel RCS attempts to connect to Intel AMT on its IP address but as it is Intel WiFi interface which is not yet enabled at AMT FW level - it will get not response.
See my other response - for Admin Control mode use 3 stage approach :
- configure Intel AMT via USB or Manualy via MEBx.
- Use Host Based config with WiFi connection enabled
- Reconfigure Intel AMT from RCS adding /AdminPassword mailto:MEBxP@ssw0r as configured with Host Based Configuration in HBC AMT profile> as ACUConfig parameter!)
rgds
Dariusz Wittek
Intel EMEA Biz Client Solution Architect
