Intel vPro® Platform
3059 Discussions
Unprovisioning HP 7800 AMT 2.x systems
SWood7
We need to unprovision many AMT 2.x systems that have been wiped and prepared to retirement. Is there a way to boot them to a USB and run the Unprovision.exe tool on each one?
Since you have no OS the easiest way is to pull the coin CMOS battery for 5 minutes.
We finally resorted to removing the battery for a minute to reset everything. We did manage to boot (via USB) into a Microsoft Disaster and Recovery Toolset that has a Win8 WinPE image on it. We ran UnProvisionEx.exe from there but it returned nothing. Just a plain C:\ prompt. Does UnProvisionEx.exe need .NET framework to connect to AMT?
Alan_A_Intel
Sandy,
Removing the CMOS battery resets all data in the MEBx back to their default values. If you've pulled the CMOS battery like Greg suggested, then the computer has already been unprovisioned.
Also, to answer your question about the UnprovisionEx.exe tool, yes you do need the .NET Framework for it to run.
-Alan
Thanks Alan. That took care of it for us.
