Intel vPro® Platform
3053 Discussions
Virtualization/DP45SG/Q9650/vPro
I will realy apreciate a help on these quetiosn:
  1. P45 Supports DDR2 as well as DDR3. What about DP45SG; Does it ONLY Support DDR3?
  2. P45 Supports Virtualization. Does DP45SG?
  3. Are vPro and Virtualization two different and independent things?
I will aprciate your help in this regard,
Wth Thanks,
Amit Saxena
Hello Amit,
Here are the information that you have asked earlier.
Memory Support:
Only DDR3
Website: http://support.intel.com/support/motherboards/desktop/dp45sg/sb/CS-029151.htm http://support.intel.com/support/motherboards/desktop/dp45sg/sb/CS-029151.htm
Apparently, the board DP45SG does not support Virtualisation as it is not available on the TPS.
Vpro and Virtualisation are two different things.
Information on VPro on Website:
http://www.intel.com/products/vpro/index.htm http://www.intel.com/products/vpro/index.htm
Boards that support Vpro technology:
DQ45CB
DQ45EK
DQ35JO
DQ35MP
VPro is just a platform technology, that supports:
Built-in Management
Managed – reduce your support costs with built-in management technologies*
Proactive Security
Safer – protect your PCs and your data infrastructure with built-in security technologies
Energy Efficient Performance
Energy Efficient Performance – improved performance with reduced power consumption with the Intel® Core™2 Duo processor inside
To be able to get a VPro Logo, you will need to have some hardware specifications for that.
Intel® Core™ 2 Duo E6xx0 sequence w/ Intel Virtualization and Trusted Execution Technologies, other CPUs as well
Q family chipset with ICHx-DO
TPM 1.2
Intel® VTx capable BIOS
Intel® VTd capable BIOS
Virtual Appliance capable BIOS
Intel® TXT capable BIOS
Intel® AMT capable BIOS
TPM 1.2 capable BIOS
Intel® AMT Firmware
82566DM Gigabit LAN
Intel® AMT Status Icon
So to be able to pass the VPro test, the board needs to support VT.
Hope this helps.
Aryan.
