currently I am comparing the MeshCommander and the Intel Manageability Commander for configuring AMT Version 12.
With the MeshCommander I was able to configure AMT Version 12 for a TLS connection.
But I found no way to do the same with the Intel Manageability Commander.
1. Where are the setting in the Intel Manageability Commander for TLS configuration?
2. How can I configure TLS with Intel Manageability Commander?
Regards and thanks in advance for helpful answers
jo123
Thank you for contacting Intel® AMT/SCS/Manageability Commander Community.
Please check the following user Guide for Intel® Manageability Commander on page 8 of this document you will see more information about how to set up and use the TLS when you will add a computer or system:
If you have any other questions, please feel free to reply back and I will be more than happy to assist you.
Emeth O.
Under Contract to Intel Corporation.
I was reviewing this thread and I would like to know if you have any other questions or if I can help you with something else? If so, please do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
A Contingent Worker at Intel
Hi Emeth,
sorry on page 8 of the mentioned document.... is not the neeed information.
We need to know:
- Where are the settings for TLS in the Intel Manageability tool ?
- Where do I refer the certificate for TLS in the Intel Manageability tool?
Please check the following Guide:
https://www.intel.com/content/dam/support/us/en/documents/software/Intel_SCS_User_Guide.pdf
On section 5.10, the guide will refer you to the TLS details and configuration.
Please let me know if this information helps you.
Emeth O.
I am following up on your case in order to verify if there is anything else I can help you with.
Emeth O.
Hi Emeth,
with the MeshCommander we can easily configure TLS connections to iAMT version 12 …
But we also need to know how we can do the same with the Intel Manageability Commander... But we war not able to do that....
We need to know:
1. Where on the computer, on which we run the Intel Manageability Commander, do we have to place the needed certificate?
2. We need to know all steps, that must be done in the Intel Manageability Commander, to establish a TLS connection to iAMT version 12.
==> Can you please provide us exactly these information. That would be great.
regards and thanks in advance
Jo123
Hi Andreas,
Thank you for the time you have been waiting for my response.
I am still working on this in order to provide you the most accurate information.
Meanwhile, please check the following guides:
User Guide for Intel® Manageability Commander
Intel® Setup and Configuration Software (Intel® SCS) User Guide
Introduction to Intel® AMT RCFG Certificate Selection
Intel® AMT Configuration Utility User Guide
Let me know if the information you need is on those guides.
As soon as possible I will be getting back to you with the next step.
Regards.
Emeth O.
Hi Andreas,
Intel Manageability Commander does not have the same functionality built-in to create a TLS certificate as MeshCommander does.
Emeth O.
Hi Andreas,
I am following up on your case in order to verify if you still need help with this.
Please if you have any other question, do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
Hi Emeth,
ok may be you can not create certificates in the Intel Manageability tool. That might be right.
But I think somehow you can us it to connect via TLS with iAMT V12.
1. I need to know the clear steps ( step by step ), how I configure that in the Intel Manageability tool.
2. I also need to know, how I can refence in the Intel Manageability tool the certificate, which is need for TLS.
Can you please provide me these 2 information.
I previously provided you with the configuration guides about the Intel Manageability tool.
By any chance, do you need help with a specific step?
Emeth O.
I was reviewing your thread and I would like to know if you have any other questions?
Emeth O.
I was checking this thread, but I have not seen any activity recently.
If you have any additional questions, please proceed and create a new thread.
Have a wonderful day.
Emeth O.
