Intel vPro® Platform
Intel Manageability Forum (Intel® EMA, AMT, SCS & Manageability Commander)
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
2608 Discussions
Why is my Intel 915 Gag using 1.440 gig memory for system resorces?
Community Manager
Why is my Intel Motherboard 915 gag using 1.440 gig of memory for system resorce when I have an Nvidia 8600GT graphics card installed and 4 Gig of matched KingstonHyper X ram of which there is only 2,560 gig left after the board has grabbed the 1.440 stated above. Thanks for any help. Is there something I could change in the bios?
NFlee
Hi Tazman,
I presume you have the Intel D915GAG? When posting questions it really is good practice to give all the information.
I fix tractors for a living and I really do question my customers first, that way I can narrow down the reason for their problem, but here goes.
A couple of things jump right out at me. If you carefully go through them, you will either fix the problem or find the reason for this occurring.
1. Are you sure that you have the memory sticks in the correct slots? Checking on this site I find that your board likes its memory in the first slot if using one stick; first and third if using two sticks; and first, second and third if using three sticks. I think you said your memory is identical, so from that, you are using two or more sticks, this should give you dual configuration, IF they are of the same type AND frequency.
2. Are the memory sticks actually supported by this board? Have you checked this? You can do so at this site. If the memory is not supported then the O.S. will try to use the C;/ drive as memory and use further system resouces doing so.
3. Is this a new install or not? The reason for asking is that malware will use resources, especially Trojans! You may use various software to remove these, but to ensure that you REALLY do have a clean system, I would go to Majorgeeks and take "Chaslang's advice for malware removal.
The latest bugs are very good at not revealing themselves to normal methods. His method is involved and very few people have the patience to properly carry this out. It will take the best part of a day to do. The results however will reward you with a snappy, quick computer, that is a joy to use.
Hope this helps you
kind regards
Nick.
