Intel vPro® Platform
3052 Discussions
ZTClocalagent activation issues
Hi all,
I am fairly new to vPro and trying to use the SDK on my AMT enabled HP 8440p laptop. I setup the basic AMT settings when I bought the computer in BIOS itself. Then when I started looking at the SDK, I downloaded it and when I perform discovery using ztclocalagent, it is successful. Here is a snippet of the output:
Intel AMT code versions:
Flash: 6.0.40
Netstack: 6.0.40
AMTApps: 6.0.40
AMT: 6.0.40
Sku: 24584
VendorID: 8086
Build Number: 1215
Recovery Version: 6.0.40
Recovery Build Num: 1215
Legacy Mode: False
Setup and Configuration:
Completed
Found 8 certificate hashes in following Handles:
0,1,2,3,4,5,6,7,"
However, when I try to use ZTClocalagent -activate, I run into errors and I am trying to get a feel what why I am getting these errors and how I can fix them:
Zero Touch Configuration:
enabled
Provisioning TLS Mode:
PKI
Failed performing Start Configuration command:
PT_STATUS_INVALID_PT_MODE: Command is not permitted in current operating mode.
Activate Intel AMT configuration:
Failure
Appreciate any inputs to help me with the same.
Sudarsan VS.
Sudarsan,
Are you using Windows Vista or 7? If so, make sure you launch your command prompt as Administrator when running the ZTClocalagent.
Sudarsan,
